Electric self launching system update
Old April 9th 19, 03:07 PM posted to rec.aviation.soaring
Emir Sherbi
Default Electric self launching system update
El lunes, 8 de abril de 2019, 21:43:09 (UTC-3), tienshanman escribió:
Emir Sherbi;986843 Wrote:
El lunes, 8 de abril de 2019, 0:19:32 (UTC-3), Roy E escribió:-
Emir,
What is the prop diameter?
What is the weight of the complete motor assembly?
What are the dimensions of the space, which this assembly occupies when
retracted?
Thanks,
Roy-
Roy,
1m Prop diameter.
Total weight for the self launching configuration is near and below
55kg. Including the structural reinforcement.
The motor bay is 1m long, 0,24m width, 0,35m tall at front, 0,25m at the
back.
What gliders can this be built into and how would the process work?
Where would installation take place?
tienshanman
Without much redesign, gliders that originally have water ballast bags. If you have "wet wings" we have to search a place on the fuselage for the battery packs.
That means that ASW19/20 - Pegasus - LS1/3/4 and others can be modified without much redesign.
The modification would take place in the US. Depending on the orders and the locations of the gliders.
Old June 6th 19, 09:11 PM posted to rec.aviation.soaring
Emir Sherbi
New update vÃ*deo:
https://youtu.be/a63rowfxEJo
Old June 28th 19, 02:33 AM posted to rec.aviation.soaring
Matt McBee
Hi Emir,
I am keenly following your updates.
How is the 55 kg weight you mentioned distributed between battery weight (in the wings) and fuselage weight? I am considering the maximum weight of non-lifting parts on my glider, which might prohibit this modification if all 55 kg is carried in the fuselage.
Matt
Old June 28th 19, 01:43 PM posted to rec.aviation.soaring
Charlie Quebec
A rule of thumb would be the battery being at least 2/3rds of the weight.
The FES total is about the same, the battery is 30 kg I believe.
Old June 28th 19, 01:47 PM posted to rec.aviation.soaring
Emir Sherbi
Matt,
Thanks for your support.
The battery pack is designed to be inside of the wings. So you will be adding 20-25kg to the non lifting components only.
If your glider is registered as experimental is possible to change the flight envelope and rise the max weight.
Regards
El jueves, 27 de junio de 2019, 22:33:31 (UTC-3), Matt McBee escribió:
Hi Emir,
Matt
Electric Self Launch System Emir Sherbi Soaring 31 October 28th 18 04:53 AM
Electric Self Launching System Emir Sherbi Soaring 0 June 4th 18 04:54 PM
FES&electric system batteries krasw Soaring 33 February 25th 17 04:17 PM
ASW24 - electric valve system Norbert Gulczynski Soaring 1 January 25th 15 01:13 PM
Relief System Update [email protected] Soaring 4 March 16th 07 03:49 AM
