Electric self launching system update
Old April 3rd 19, 10:02 PM posted to rec.aviation.soaring
Emir Sherbi
Default Electric self launching system update
Here is a short video of the pylon's manual operation.
https://youtu.be/a90EUIrYEYw
Regards
Old April 5th 19, 01:14 AM posted to rec.aviation.soaring
Steve Koerner
Cool.
Are you developing this to be a product for adoption on experimental gliders?
Will it have sufficient power for self launch or just as sustainer?
Old April 5th 19, 03:04 AM posted to rec.aviation.soaring
Emir Sherbi
El jueves, 4 de abril de 2019, 21:14:34 (UTC-3), Steve Koerner escribió:
Cool.
Yes, its intended to be sold and installed on experimental gliders. I am not planning to make a supplemental type certificate for now.
Depending on you need. We can build the battery pack for self launch capabilities or to optimize range for sustainer only.
Regards
Old April 6th 19, 05:56 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Emir Sherbi wrote on 4/3/2019 2:02 PM:
The retraction is done manually with a lever in the cockpit?
What is the motor horsepower?
- "Transponders in Sailplanes - Dec 2014a" also ADS-B, PCAS, Flarm
http://soaringsafety.org/prevention/...anes-2014A.pdf
Old April 7th 19, 12:02 AM posted to rec.aviation.soaring
Emir Sherbi
Yes, the motor is extended and retracted manually.
The power is around 40hp. But we have to test the power consumption of the propeller at the propeller's rpm limit.
Old April 7th 19, 03:30 AM posted to rec.aviation.soaring
Eric,
If you watch the video carefully (the lighting is not too good in the cockpit) you can watch the manual extension. It doesn't appear to require any extreme effort.
RC
Old April 8th 19, 03:17 AM posted to rec.aviation.soaring
Emir Sherbi
Regards
What gliders can this system be built into and what is the cost?
gotovkotzepkoi
Without much redesign, gliders that originally have water ballast bags. If you have "wet wings" we have to search a place on the fuselage for the battery packs.
For the price, i am trying to achieve a price of 15.000USD installed. I am looking for other providers for lowering some production and part costs. But now is currently more near the 18.000 installed.
Regards
Old April 8th 19, 04:19 AM posted to rec.aviation.soaring
Roy E
Emir,
What is the prop diameter?
What is the weight of the complete motor assembly?
What are the dimensions of the space, which this assembly occupies when retracted?
Roy
Old April 8th 19, 04:54 AM posted to rec.aviation.soaring
Emir Sherbi
El lunes, 8 de abril de 2019, 0:19:32 (UTC-3), Roy E escribió:
Emir,
Roy
Roy,
1m Prop diameter.
Total weight for the self launching configuration is near and below 55kg. Including the structural reinforcement.
The motor bay is 1m long, 0,24m width, 0,35m tall at front, 0,25m at the back.
Old April 8th 19, 08:46 PM
tienshanman tienshanman is offline
Member
First recorded activity by AviationBanter: Jan 2009
Quote:
Emir,
Roy
Roy,
1m Prop diameter.
What gliders can this be built into and how would the process work? Where would installation take place?
Electric Self Launch System Emir Sherbi Soaring 31 October 28th 18 04:53 AM
Electric Self Launching System Emir Sherbi Soaring 0 June 4th 18 04:54 PM
FES&electric system batteries krasw Soaring 33 February 25th 17 04:17 PM
ASW24 - electric valve system Norbert Gulczynski Soaring 1 January 25th 15 01:13 PM
Relief System Update [email protected] Soaring 4 March 16th 07 03:49 AM
