source for clips or sleaves for Hotelier linkages
Old August 2nd 19, 01:29 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Default source for clips or sleaves for Hotelier linkages
On Friday, August 2, 2019 at 2:10:38 AM UTC-4, John Foster wrote:
On Thursday, August 1, 2019 at 8:09:20 PM UTC-6, Bruce wrote:
Well, I found a source for the pins, and it's local to me, of all places--Ace Hardware! 0.047" (1.2mm) dia. by 19/32" (15mm) long. When I insert them into the holes I drilled, they barely protrude beyond the diameter of the push rod, and will easily clear the holes in the wing root rib. 32 cents each.
So which pins did you end up using? The "bobbie" pins or other? Enquiring minds want to know
Bruce
If you have Facebook, check this link out:
https://www.facebook.com/photo.php?f...type=3&theater
"Sorry, this content isn't available right now
The link you followed may have expired, or the page may only be visible to an audience you're not in."
Old August 2nd 19, 03:15 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Maybe a keyword to search the Ace Hardware website?
Steve Leonard
Phoebus C
N9213
Wrk No. 778
Old August 2nd 19, 08:21 PM posted to rec.aviation.soaring
For those of us lucky enough to have to put those pins in, the best tool is a really bright flashlight. It’s relatively easy if you can put a bright light right on the connection. It’s next to impossible to do it blind.
John Foster
Steve Leonard
Phoebus C
N9213
Wrk No. 778
I've done an extensive search on the Ace Hardware website, and I don't see them listed online. I really wish we could post photos here. I've tried uploading the photo to PhotoBucket, but that seems to be giving me hassles as well. Any other ideas of posting photos of this?
Old August 2nd 19, 09:16 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Your Facebook page appears to be Public. Maybe another attempt to post a picture on your timeline?
Steve Leonard
Old August 2nd 19, 09:39 PM posted to rec.aviation.soaring
Dan Marotta
And another good tool is a hemostat
https://www.amazon.com/SE-610FS-Self-Locking-Straight-Stainless/dp/B009NYW2W8/ref=asc_df_B009NYW2W8/?tag=hyprod-20&linkCode=df0&hvadid=312270925393&hvpos=1o1&hvne tw=g&hvrand=10767409606582083748&hvpone=&hvptwo=&h vqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9030615 &hvtargid=pla-436320895618&psc=1&tag=&ref=&adgrpid=61740029226&h vpone=&hvptwo=&hvadid=312270925393&hvpos=1o1&hvnet w=g&hvrand=10767409606582083748&hvqmt=&hvdev=c&hvd vcmdl=&hvlocint=&hvlocphy=9030615&hvtargid=pla-436320895618.
It's long and thin, and locks on the part.
Dan, 5J
Old August 2nd 19, 09:40 PM posted to rec.aviation.soaring
Dan Marotta
Dropbox.Â* On your dropbox, select the file you want to show, right
click, select "Copy Dropbox Link", and paste that link into your message.
Steve Leonard
Phoebus C
N9213
Wrk No. 778
Dan, 5J
Old August 2nd 19, 10:45 PM posted to rec.aviation.soaring
John Foster
Let’s try this:
https://photos.app.goo.gl/w6meRLjLQfb9dT6V6
Old August 2nd 19, 10:50 PM posted to rec.aviation.soaring
Bruce
On Friday, August 2, 2019 at 2:45:05 PM UTC-7, John Foster wrote:
Let’s try this:
Photo Worked It's an R-Clip!
Old August 3rd 19, 01:52 AM posted to rec.aviation.soaring
Steve Leonard[_2_]
On Friday, August 2, 2019 at 4:45:05 PM UTC-5, John Foster wrote:
Let’s try this:
Thank you, John. It is what I suspected, but good to see confirmation!
Steve Leonard
Source for L'Hotellier Safety Clips George Haeh Soaring 23 January 29th 19 12:20 AM
L'Hotelier Fitting Safety Pins Dan Marotta Soaring 20 October 17th 16 01:40 AM
Complete Hotelier Connections For Sale (Brand New) $400 Scott Alexander[_2_] Soaring 2 July 19th 12 10:40 PM
Hotelier safety sleeves [email protected] Soaring 6 August 31st 07 03:41 PM
Lycoming throttle linkages Evan Carew Home Built 0 September 29th 04 01:58 AM
