#21
On Friday, August 2, 2019 at 2:21:12 PM UTC-5, wrote:
For those of us lucky enough to have to put those pins in, the best tool is a really bright flashlight. It’s relatively easy if you can put a bright light right on the connection. It’s next to impossible to do it blind. Swanson - I have to disagree on it being impossible to put the R-clip in blind. I suppose it all depends on the glider. My (beloved) DG-101 had a turtle deck hatch and no amount of lighting was going to help the situation of looking into a jet black hole surrounded by sun lit bright white gel coat.. You had to do it blind (especially the dive brakes which were located at the wing root). |
On Friday, August 2, 2019 at 4:45:05 PM UTC-5, John Foster wrote:
Let’s try this: https://photos.app.goo.gl/w6meRLjLQfb9dT6V6 John - You really need to put a leash on these frisky R-clips to keep them from jumping into the belly of the beast and lodging in places you REALLY want to avoid. |
On Friday, August 2, 2019 at 7:03:44 PM UTC-6, John DeRosa OHM Ω http://aviation.derosaweb.net wrote:
On Friday, August 2, 2019 at 4:45:05 PM UTC-5, John Foster wrote: Let’s try this: https://photos.app.goo.gl/w6meRLjLQfb9dT6V6 John - You really need to put a leash on these frisky R-clips to keep them from jumping into the belly of the beast and lodging in places you REALLY want to avoid. I will do that. That is a great idea. From reading above, dental floss should work? |
#24
Dental floss works, also any other strong, thin cord. When you tie the knot around the pin, use a dot of hot melt glue to fix it to the pin. Cords and knots eventually stretch and loosen. The glue over the knot and pin eliminates this. |
#25
![]() Quote:
After going the pin route the clips are a god send . You don't need to tie anything onto them to prevent them from falling into the abyss . |
#26
![]() On 8/3/2019 4:29 AM, Delta8 wrote: After going the pin route the clips are a god send . You don't need to tie anything onto them to prevent them from falling into the abyss . .... Until one slips out of your fingers. -- Dan, 5J |
#27
The phoebus connections are made outside the fuselage, if dropped the pins fall to the ground. I keep mine in an altoid tin along with the pin for the Jesus rod. Gives me one more positive check that pins are in. Box empty, pins in.
Any sources for plastic hemostats (with bent ends)? On the phoebus you have to reach into the wing and pull the brake rod out for hookup. I plasti-dipped a set of pliers but would rather have a plastic set. I was told that using pliers could score the connector ball, not desirable. JD |
#28
On Saturday, August 3, 2019 at 9:53:11 AM UTC-5, JD Williams wrote:
The phoebus connections are made outside the fuselage, if dropped the pins fall to the ground. I keep mine in an altoid tin along with the pin for the Jesus rod. Gives me one more positive check that pins are in. Box empty, pins in. Any sources for plastic hemostats (with bent ends)? On the phoebus you have to reach into the wing and pull the brake rod out for hookup. I plasti-dipped a set of pliers but would rather have a plastic set. I was told that using pliers could score the connector ball, not desirable. JD Hey JD, The phoebus uses a small aluminum "fork" tool to extract the control rods from the fuselage or wing. Maybe someone can send you a picture of the originals, I made a few, but I sent them with the glider when I sold it. Good Luck, Scott |
#29
My clips are inserted in the connector approximately 17 feet from the
fuselage.Â* No chance of dropping them inside. :-DÂ* For me the string is to catch the clip, should I drop it, so it's not lost on the ground. Jesus rod? On 8/3/2019 8:53 AM, JD Williams wrote: The phoebus connections are made outside the fuselage, if dropped the pins fall to the ground. I keep mine in an altoid tin along with the pin for the Jesus rod. Gives me one more positive check that pins are in. Box empty, pins in. Any sources for plastic hemostats (with bent ends)? On the phoebus you have to reach into the wing and pull the brake rod out for hookup. I plasti-dipped a set of pliers but would rather have a plastic set. I was told that using pliers could score the connector ball, not desirable. JD -- Dan, 5J |
#30
On Saturday, August 3, 2019 at 10:26:04 AM UTC-5, Dan Marotta wrote:
Jesus rod? Dan, 5J Main wing pin. Lose it, meet Jesus. Steve Leonard |
Source for L'Hotellier Safety Clips | George Haeh | Soaring | 23 | January 29th 19 12:20 AM |
L'Hotelier Fitting Safety Pins | Dan Marotta | Soaring | 20 | October 17th 16 01:40 AM |
Complete Hotelier Connections For Sale (Brand New) $400 | Scott Alexander[_2_] | Soaring | 2 | July 19th 12 10:40 PM |
Hotelier safety sleeves | [email protected] | Soaring | 6 | August 31st 07 03:41 PM |
Lycoming throttle linkages | Evan Carew | Home Built | 0 | September 29th 04 01:58 AM |
