Wanted to buy, Dittel radio wiring harness
Old September 10th 19, 05:39 PM posted to rec.aviation.soaring
Default Wanted to buy, Dittel radio wiring harness
On Tuesday, September 10, 2019 at 12:29:08 PM UTC-4, John DeRosa OHM Ω http://aviation.derosaweb.net wrote:
On Tuesday, September 10, 2019 at 10:10:11 AM UTC-5, 2G wrote:
On Monday, September 9, 2019 at 6:23:52 AM UTC-7, John DeRosa OHM Ω http://aviation.derosaweb.net wrote:
Chuck,
While making or buying a harness is an option, I think that you may be pursuing the wrong approach to your problem.
You have a problem in your glider. You want to set up a bench test rig. This will only determine if the radio itself is ok or not. In my experience the radio itself doesn't fail - especially so with quality brands (Filser, Dittel, Becker, etc) but rather with wiring, power supply, antenna, etc. Bottom line: your intended approach probably won't determine where your problem is within the glider.
My suggestion is to first use the troubleshooting guidelines in my presentation http://aviation.derosaweb.net/presen...s/#transceiver and see where that gets you.
If you think the problem is with the radio then send it in to a qualified repair shop. Addresses and phone numbers are listed in my presentation.
Best of Luck,
John OHM Ω
A handy instrument to have is an SWR meter, and they are pretty cheap. This will show any faults in the antenna lead (the most likely wiring fault).
Tom
Tom - Thanks. Yes, an (V)SWR meter is a handy tool for those technical folks.
To explain - This meter will measure how well your various "antenna system" components (transceiver, BNC connectors, coax wiring, and antenna) are all working together. Any one component of which can cause transmit issues - especially suspect are the BNC connectors.
Simply said, the meter will indicate if things are not right by showing a high numerical reading. Anything above ~1.5 is suspect. The lower the number, 1.0 being best, the more transmit power is actually reaching the antenna.
A (simple testable) effect of having a lousy antenna system is the transceiver will draw much more current than usual which usually shows up by the battery voltage dropping from ~12Vdc to ~10Vdc or worse.
For the receive side nearly anything will work fairly well, at least for close-in transmissions.
Hey, that sounded pretty intelligent! I should add this to my presentation!!!
- John OHM Ω
Thanks John. That's great information.
Wiring Harness Needed Bob Youngblood Soaring 12 September 6th 19 10:58 PM
Dittel Dynamic Mic wiring Doug Mueller Soaring 10 February 7th 15 01:41 AM
engine monitor wiring harness install Jim Burns Owning 8 November 20th 06 02:26 PM
Dittel Radio wanted Paul Soaring 2 August 28th 05 03:12 PM
looking for Dittel FSG 60M wiring diagram ken ward Soaring 1 May 29th 05 02:54 AM
