Kawa rough landing?
Old September 19th 19, 12:07 PM posted to rec.aviation.soaring
Default Kawa rough landing?
2g to answer your question, I can recover from a 1/2 turn spin within 150ft but my response has to be instinctive and instantaneous, which it has gotten thru lots of practice.
You never answered my querry, when is the last time you practiced spins, spin entry, and recovery? Do you intimately know the subtleties of your birds behavior when super slow? Whens the last time you've taken 10 pattern tows and seen how steep you can approach a landing spot and stop short? Do you know how short you can stop? Do you practice very very minimum energy landings to be able to fly the ragged edges of control when you really need to?
These are things every xc pilot should do yearly and definitely when in a new bird.
Old September 19th 19, 12:25 PM posted to rec.aviation.soaring
To paraphrase advice from Wolfgang Langewiesche in Stick and Rudder: if *anything* surprising ever happens in a turn immediately unload (i.e aerodynamically) the wing.
IMO it should be ingrained in every pilot's mind that the instant he is surprised during a turn the he should move the stick forward - only after that should he analyse the situation.
Old September 19th 19, 12:41 PM posted to rec.aviation.soaring
Well said jpg. I forgot that wolfgang quote. Thats more of a lifesaver than any "fly coordinated" mantra. Thanks
Dan
Old September 20th 19, 04:31 AM posted to rec.aviation.soaring
Andy Blackburn[_3_]
I try to teach myself to respond to a wing drop with stick forward and slightly into the wing drop (to reduce the AOA) and opposite (usually top) rudder. It's a good reflex to build.
Andy Blackburn
9B
Old September 20th 19, 08:21 AM posted to rec.aviation.soaring
waremark
Many gliders are not approved for deliberate spinning. Do you guys recommend spinning them anyway? My approach to spin avoidance is to monitor the airspeed, and to teach that if the nose ever goes down uncommanded to push the stick forwards.
Old September 20th 19, 04:04 PM posted to rec.aviation.soaring
BobW
Practice, practce, practice.
Leads to (immediate) reaction(s), reaction(s), reaction(s). Good and useful
stuff...at many levels IMO.
Most of my flight time is in 3 ship types: 1-26; (V-tailed) HP-14; Zuni. The
latter two both registered in the (USA's) Experimental category.
The only one I spun was the 1-26.Seventeen turns max one direction; 6 turns
max the other (after which it always self recovered in [as I recall] a
slipping, spiraling, dive...which I never let continue very long). Difficult
(in the asleep at the switch sense of things) to induce any sort of departure
from controlled flight at my (light) weight, much less a spin...but a great
ship in which to practice inadvertent departures...and fun to spin, too.
Difficult to imagine a safer/better glider in which to "practice spinning."
SN105, and - as always, when dealing with spinning - YMMV!
I intentionally never spun the HP because I was unconvinced it had sufficient
tail-feather power to break a fully-developed spin, and, no one was paying me
to be a test pilot. Nor did my uncommanded-departure-practice suggest 'instant
spinning' was in my immediate future. Like the 1-26 it, too, required
serious/continuing inattention to induce even a hint of wing drop, and
'instantaneous' forward stick and opposite rudder quickly set things right
within 90-degree of heading change (the most I ever let it go).
The Zuni (as shown in the ship logs) *was* spun by a(n unpaid, I think, and
intentional) test pilot, but never by me beyond the departure-related wing
drop/initial rotation because of personal-skill-related concerns associated
with overspeeding the diving recovery...buttressed by my personal
rationale/concerns about the 'guaranteed repeatability' of fully-developed
spin behavior in any bird. That said, it too was docility personified in its
'asleep at the switch' departure-related behaviors (which varied with flap
settings). How do I know? Practice, practice, practice...
And so...just to be explicit, *I* certainly don't recommend anyone play Joe
Test Pilot in the spinning sense - *especially* if the ship's POH explicitly
prohibits spins. There's a continuum of ship-behavior (and time) between an
uncommanded departure from controlled flight, and a fully-developed spin, and
'practicing sensibly' along that continuum is what I seriously recommend.
Readers are free to interpret such free advice as they wish...or misinterpret
it, too.
Memory, and muscle memory, are your friends when it comes to the unavoidable,
ever-thin(ning) margin patterns and the (should be, dry chuckle) dreaded
uncommanded departure from controlled flight...which continues to be a common
source of pilot fatalities...a good 80+ years after general pilot knollich of
spins, their causes, recommended-recovery-methodology therefrom (or not,
sigh...) were 'essentially understood.'
Practice - and common sense - can be your friends. :-)
Bob W.
This email has been checked for viruses by AVG.
https://www.avg.com
Old September 21st 19, 04:05 AM posted to rec.aviation.soaring
Tom BravoMike
Is it about their age or design? I'm curious if there are any modern gliders (not motorgliders) not approved for spinning by design - which ones? Thanks.
Old September 20th 19, 10:18 AM posted to rec.aviation.soaring
Andy Blackburn
9B
I completely agree with that Andy. And you don't always have to be flying to do that, the reflex can be reinforced sitting at home repeatedly rehearsing it in your mind.
Old September 20th 19, 04:09 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Andy Blackburn
9B
You can also fly Condor which is a GREAT tool, but nothing beats spins in the real aircraft. For the first ten years of my soaring career I made spin training an annual occurrence, in part because the instructor is the best pilot I have ever flown with. I stopped a nimbus 4 that departed within ¼ turn above a ridge, because of that training. Twenty-five years later I still make an excuse to fly with this semi-retired instructor on occasion, more aerobatics. And I still learn something new each time we fly. Slow flight is also a great was to get to know an aircraft.
Old September 20th 19, 05:28 PM posted to rec.aviation.soaring
Dan Marotta
Continuing the thread drift:Â* One day, many years ago, my partner in an
LS-6a asked me if I'd ever stalled it in landing configuration. He said
it would depart in a lively manner.Â* So, one day at the end of a flight,
and with altitude to spare, I practiced traffic pattern stalls in the
landing configuration.Â* ...And it was lively!Â* After that, I paid a lot
more attention to AoA and yaw string in the pattern.
Andy Blackburn
9B
Dan, 5J
Avro Tudor pics 2 [04/13] - Avro Tudor rough landing.jpg (1/1) Miloch Aviation Photos 0 September 11th 17 03:38 PM
Martin PBM Mariner pics 2 [09/15] - Martin-PBM-Rough-Landing.jpg (1/1) Miloch Aviation Photos 0 August 13th 17 03:04 PM
Kawa..... [email protected] Soaring 34 August 11th 14 07:43 PM
Kawa [email protected] Soaring 3 December 2nd 13 06:26 PM
PIREP: 2I3 (Rough River State Park, Falls of Rough, KY) Kyler Laird General Aviation 0 March 1st 04 12:11 AM
