Final glide
Old September 22nd 19, 12:48 PM posted to rec.aviation.soaring
s6
Default Final glide
I can use my Oudie or my Clearnav vario for final glide.
Lately my CNv final glide is 400 feet lower than my Oudie.
The Oudie is right. All the setting are the same.
I cant correct the CNv.
Any idea from other CNv user?
Gilles
Old September 22nd 19, 01:18 PM posted to rec.aviation.soaring
[email protected][_2_]
Default Final glide
Glad nobody died....’final glide’.
Have you checked/compared all the adjustable parameters?
Polars, ballast, bugs, units, winds, QNH, etc.
R
Old September 23rd 19, 05:50 AM posted to rec.aviation.soaring
JS[_5_]
Default Final glide
R
Also could be margin height, and if the CNv is set up for total energy arrival height (including a pull-up from cruise).
Old September 23rd 19, 12:42 PM posted to rec.aviation.soaring
s6
Default Final glide
Le dimanche 22 septembre 2019 07:48:02 UTC-4, s6 a écritÂ*:
Gilles
Thank you
Margin height is set at 1000 feet.
Vario behave as if set at 600 feet.
Check all setting, nothing change????
Gilles
Old September 23rd 19, 11:55 PM posted to rec.aviation.soaring
waremark
Default Final glide
Have you confirmed for each whether or not they are using total energy arrival height, ie including the expected height recovery from pull up to best glide height? That could easily account for a difference of 400 feet.
Is the difference a fixed value regardless of distance to go, rather than a percentage?
Have you checked whether the elevation of your arrival airfield is set the same in both devices?
Old September 24th 19, 12:45 AM posted to rec.aviation.soaring
Tango Eight
Default Final glide
It's either a user set up or database problem. There's no other likely possibility.
OT... but using a preset margin is sooooo 1986. Set the margin to zero and let the device tell you your predicted arrival height. If you don't like the numbers you see, do that PIC thing....
T8
Old September 24th 19, 01:54 AM posted to rec.aviation.soaring
6PK
Default Final glide
T8
snip
"OT... but using a preset margin is sooooo 1986"
I beg to disagree with you sir. This is YOUR preference and opinion and maybe other's too and that is ok... but, using a safety margin is strictly a personal preference of others and no it does not go out of style like you so imply above..
Old September 24th 19, 02:13 AM posted to rec.aviation.soaring
Tango Eight
Default Final glide
T8
snip
It was dumb in 1986 too :-).
No one arrival height covers all situations.
T8
Old September 24th 19, 02:30 AM posted to rec.aviation.soaring
6PK
Default Final glide
T8
snip
T8
Of course not but it is still personal a personal preference, no need to be opiniated, there is always more than one way to skin a cat.
Old September 24th 19, 03:01 AM posted to rec.aviation.soaring
Tango Eight
Default Final glide
T8
snip
T8
Try it the other way, you'll see.
Happy landings,
T8
Clarence See....final glide Gregg Leslie[_2_] Soaring 2 December 27th 12 09:52 PM
Final glide ppp1 Soaring 8 January 6th 11 02:21 PM
Final Glide Roy Clark, \B6\ Soaring 1 December 23rd 10 04:45 PM
Stretching the Final Glide vontresc Soaring 25 December 16th 09 10:50 PM
Final Glide - JD (US) Roy Clark, B6 Soaring 1 September 19th 07 07:17 AM
