Kawa rough landing?
Old September 23rd 19, 06:57 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Default Kawa rough landing?
2G wrote on 9/22/2019 9:21 PM:
On Sunday, September 22, 2019 at 8:15:41 PM UTC-7, Eric Greenwell wrote:
2G wrote on 9/22/2019 1:43 PM:
The bottom line is that the total drag of the 26e prop+mast+radiator+engine bay doors drops the glide from 50:1 to 17:1. At best, what you are arguing about is the relative contribution of these elements - my bet is on the prop being the largest. But the only thing that matters is the total drag..
Don't forget the massive landing gear that puts the wheel and tire almost entirely
outside the fuselage (and it has doors with a frontal section nearly as big as the
engine doors)!
I'll have to redo my measurements of years ago. I recall getting about 20:1 in
landing configuration, but I can't find my notes. Who did the 17:1 measurement?
Another data point: In 2008, Dr Jack had the belt break on his 26E, stopped the
engine, but was unable to stop the freely spinning propeller. He wrote "From my
GPS trace the glide ratio during the straight portion of my descent, at around 55
kts in flap 3 with prop spinning, as 18.5"
So, gear up, but prop spinning, he was able to glide about 7 NM to an airport,
then encountered some lift and thermalled up, and briefly considered thermalling
the 11 NM to his home airfield, but decided it was smarter to land. Hardly sounds
like a glider in "plummet mode"?
Old September 23rd 19, 07:03 PM posted to rec.aviation.soaring
So the moral of all this is that motor equiped sailolane fliers should get some 1-26 xc time?
LOL
Old September 23rd 19, 08:24 PM posted to rec.aviation.soaring
engine doors)!
I had a non start(pilot induced) the other day in my ASG-29E. I was positioned on down wind for my selected field. Rather than mess with the engine(and associated distraction)I put the gear down and landed normally. Since I usually fly a fairly steep approach, I did not sense any meaningful affect on my landing.
FWIW
UH
Old September 26th 19, 08:21 PM posted to rec.aviation.soaring
5Z
When I had my '26E, I once flew several self launches to pattern altitude, shut down the engine and landed with the prop extended. It was a complete non-event and felt the same as a pattern and landing in an ASK-21. I like to fly a high and steep final so maybe that's why. I probably used less spoiler in the '26E to maintain the same approach angle. I also applied landing flaps sometime between base and final.
When making a "straight in" type final glide with just a couple hundred feet arrival when some distance out, I'd pick a (or already have one in mind) a few miles out if it still looked marginal. I'd then start the engine, make a few orbits over the safety field to gain altitude, then motor home. Once home, I'd retract the engine part way to cool it and make a landing.
I once joined a ASW-20B in an extremely weak thermal, shut down the motor and again lowered it to the slightly extended cooling position. We were pretty much even in climb and even while gliding to another thermal a mile or two away. So my takeaway there is that at speeds around 60 knots, the open engine doors and partly extended engine produce negligible drag.
IMHO, the dire warnings about poor LD on the POH are there to avoid any liability if someone decides to sue after an engine extended mishap. Or to be a bit kinder, like what we tell new glider pilots about thermalling low - stop trying to stay up and just land once at XXXX above ground.
5Z
Now flying ASW-27b
Old September 26th 19, 09:13 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
5Z wrote on 9/26/2019 12:21 PM:
The "slightly extended cooling position" is about 30 degrees from the fuselage.
There is still all the stuff hanging in the breeze: the propeller, the radiator,
almost the entire mast, and the doors are fully open. It looks dreadfully draggy
to a pilot circling in the same thermal with you, but it's just like Tom says: the
drag is so small, you don't know it's there.
Old September 26th 19, 09:30 PM posted to rec.aviation.soaring
JS[_5_]
Got so concerned with staying under the LAS Class B once, didn't completely put away the ASH26E mast until after a cruise to the second thermal. A bit noisy but no big deal.
Once climbed in the 26 together with a Discus 2. I still had the mast in cooling position, the D2 was "P7". Impressed!
Enjoying Fred Drift this time, Seems like Kawa was being condemned for nothing.
Old September 27th 19, 02:17 AM posted to rec.aviation.soaring
2G
Right - here is a flight where I forgot to complete the cool-down process and flew for 3 hours with the prop in that position:
https://www.onlinecontest.org/olc-3....l?dsId=7393456
It is really hard to determine the glide degradation with the prop out, but I am sure there is some.
Tom
Old September 27th 19, 01:57 AM posted to rec.aviation.soaring
Dave Nadler
Eric and 5Z - Please don't ASSUME that all gliders are as benign as 26
with motor out and stopped. They are not. You are doing the community a
great disservice by ASSUMING that its not a big problem for some gliders.
Including types with many in service.
Please be safe out there,
Best Regards, Dave
Old September 27th 19, 02:19 AM posted to rec.aviation.soaring
2G
Best Regards, Dave
And you are doing the community a disservice by not naming those MGs. We are, at least, speaking from first-hand knowledge and ALWAYS state the gliders that we have direct experience with.
Tom
Avro Tudor pics 2 [04/13] - Avro Tudor rough landing.jpg (1/1) Miloch Aviation Photos 0 September 11th 17 03:38 PM
Martin PBM Mariner pics 2 [09/15] - Martin-PBM-Rough-Landing.jpg (1/1) Miloch Aviation Photos 0 August 13th 17 03:04 PM
Kawa..... [email protected] Soaring 34 August 11th 14 07:43 PM
Kawa [email protected] Soaring 3 December 2nd 13 06:26 PM
PIREP: 2I3 (Rough River State Park, Falls of Rough, KY) Kyler Laird General Aviation 0 March 1st 04 12:11 AM
