Kawa rough landing?
Old September 23rd 19, 11:08 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Default Kawa rough landing?
john firth wrote on 9/23/2019 1:48 PM:
On Saturday, August 31, 2019 at 3:31:32 PM UTC-4, Jonathan St. Cloud wrote:
Not sure how accurate FB translate is, but it appear as if Mr. Kawa had some sort of incident with an electric motor not working and a rough uphill landing. Gas, electric or jet be careful guys!
Re prop drag;
At the end of towing in the Citabria, I would cut the engine and then stall
it to stop the wind-milling. This reduced the for a reasonable L/D.
However, a wind-milling prop running free probably has much less drag than
stationary prop.
Who will perform a test?
http://www.peter2000.co.uk/aviation/misc/prop.pdf
The article concludes "it depends"; briefly, high pitch - let it rotate, low
pitch, stop it. Other sources pointed out helicopters autorotate to slow their
descent with the engine disconnected, and clearly that's slower than stopping the
blades!
I'm guessing a 26E with a broken belt has more drag from the spinning prop than a
stopped prop, but do not plan any testing; however, I will be happy to do a
comparison glide with another 26E that has the belt removed. That could be done on
the ground, and then glider towed to height required for the test glide.
Old September 23rd 19, 11:52 PM posted to rec.aviation.soaring
Interesting rotating verses stationary, I always was taught in power that a rotating prop was more drag than a stopped one as the rotating one acted more like a "disc" than just 2 blades stopped. But know real evidence of that.
CH
Old September 24th 19, 01:24 AM posted to rec.aviation.soaring
We should get an aero engineer to comment but in simple terms the AOA of the prop can become negative with a windmilling prop(depending on pitch design and rotational speed). If that happens you get negative thrust.
Old September 24th 19, 04:26 AM posted to rec.aviation.soaring
2G
Here is a study of the subject:
Conclusion: it depends.
In this paper the same conclusion is reached (note the date):
http://naca.central.cranfield.ac.uk/...report-464.pdf
Tom
Avro Tudor pics 2 [04/13] - Avro Tudor rough landing.jpg (1/1) Miloch Aviation Photos 0 September 11th 17 03:38 PM
Martin PBM Mariner pics 2 [09/15] - Martin-PBM-Rough-Landing.jpg (1/1) Miloch Aviation Photos 0 August 13th 17 03:04 PM
Kawa..... [email protected] Soaring 34 August 11th 14 07:43 PM
Kawa [email protected] Soaring 3 December 2nd 13 06:26 PM
PIREP: 2I3 (Rough River State Park, Falls of Rough, KY) Kyler Laird General Aviation 0 March 1st 04 12:11 AM
