Final glide
Old September 24th 19, 03:59 PM posted to rec.aviation.soaring
6PK
Default Final glide
On Tuesday, September 24, 2019 at 7:29:21 AM UTC-7, waremark wrote:
I use an arrival height reserve. When flying to a destination airfield I readily and easily make mental adjustments up and down from it depending on conditions and distance to go. For me the benefit of setting the arrival height reserve is that if I see a green blob on my moving map when I am away from base I know that I have a fighting chance of reaching an alternate airfield. If you use a zero reserve then a green blob on the moving map is meaningless and you have to read the arrival height beside it.
By the way, at startup (after the gps has acquired) I check to see that the arrival height at the airfield I am sitting on is approximately minus my arrival height reserve. If the OP does this it might help him diagnose his problem. OP, please do report back to us on any further findings.
Ditto..
Clarence See....final glide Gregg Leslie[_2_] Soaring 2 December 27th 12 09:52 PM
Final glide ppp1 Soaring 8 January 6th 11 02:21 PM
Final Glide Roy Clark, \B6\ Soaring 1 December 23rd 10 04:45 PM
Stretching the Final Glide vontresc Soaring 25 December 16th 09 10:50 PM
Final Glide - JD (US) Roy Clark, B6 Soaring 1 September 19th 07 07:17 AM
