The earli Cirri did not come from the factory with ballast. Many were retrofitted in the field with bags.
On Mon, 30 Sep 2019 08:43:16 -0700, Tony wrote:
The earli Cirri did not come from the factory with ballast. Many were retrofitted in the field with bags. Yep. Initial Standard class rules said no water ballast and no retractable landing gear. I don't know whether the rule changes to allow water ballast and retractable gear were simultaneous or not. -- Martin | martin at Gregorie | gregorie dot org |
On Monday, September 30, 2019 at 5:19:18 PM UTC+1, Martin Gregorie wrote:
On Mon, 30 Sep 2019 08:43:16 -0700, Tony wrote: The earli Cirri did not come from the factory with ballast. Many were retrofitted in the field with bags. Yep. Initial Standard class rules said no water ballast and no retractable landing gear. I don't know whether the rule changes to allow water ballast and retractable gear were simultaneous or not. -- Martin | martin at Gregorie | gregorie dot org Many thanks for all your replies. I have contacted Schemp Hirth as well to see if they can shed any information on it. I will post here if I find out any more nuggets of information. All the best Ian |
On Mon, 30 Sep 2019 13:37:34 -0700, Ian Simmonds wrote:
I have contacted Schemp Hirth as well to see if they can shed any information on it. According to Wikipedia, so this MUST be right!, the Standard Class started in the late '50s, so think of a Ka6 as the archetypical original spec Standard Class glider. The rules changed to allow retracts in 1970 and water ballast in 1972. My 201 Libelle was built in late '69 so must have been one of the first to have retracts fitted as standard and was not fitted for water ballast, which is just as well since my wing skins are glass/balsa/glass laminates. However, it is a little odd that your '73 Std Cirrus didn't originally carry water. After all, it was built after water ballast became legal for the class in 1972. Maybe, as somebody said, it was an optional extra? -- Martin | martin at Gregorie | gregorie dot org |
Schempp-Hirth TN 278-3 indicates that from serial numbers 1-134 water ballast was optional, and standard equipment from 135 onwards.
Nick. |
Having said this, yours is likely later serial number than 135 & doesn't have water ballast. Presumably if a customer ordering a brand new Cirrus stated that they didn't want water, Schempp would comply.
Cheers, Nick. On Tuesday, October 1, 2019 at 10:17:51 AM UTC+9:30, Nick Gilbert wrote: Schempp-Hirth TN 278-3 indicates that from serial numbers 1-134 water ballast was optional, and standard equipment from 135 onwards. Nick. |
On Tuesday, October 1, 2019 at 1:51:02 AM UTC+1, Nick Gilbert wrote:
Having said this, yours is likely later serial number than 135 & doesn't have water ballast. Presumably if a customer ordering a brand new Cirrus stated that they didn't want water, Schempp would comply. Cheers, Nick. On Tuesday, October 1, 2019 at 10:17:51 AM UTC+9:30, Nick Gilbert wrote: Schempp-Hirth TN 278-3 indicates that from serial numbers 1-134 water ballast was optional, and standard equipment from 135 onwards. Nick. Hi Nick My works number (I believe that is what it is called) is 349G, however no water ballast. I guess its like ordering a car with optional extras! It doesn't seem to have really affected her performance though — looking through her paperwork she has numerous 500k, 300k, 100k flights and will probably be more aircraft than I'll be able to handle. The gelcoat is absolutely on point too - wings and fuselage looking almost brand new, with just a few light scratches underneath where she has landed out a few times, and on areas where wings/tail connect I've heard some people say that the Grob gel coat was superior — not sure about that, perhaps mine has just been cherished. ![]() Out of interest, although its A Schemp Hirth design, it was built by Grob. Who would be better placed to tell me about it do you think, Grob or Schemp? All the best Ian |
Jantar Standard 3 water ballast tank repair | [email protected] | Soaring | 6 | June 5th 17 12:25 PM |
ASK-21 and Grob 103 cockpit ballast weights | kirk.stant | Soaring | 12 | September 2nd 15 08:57 PM |
water ballast | 6PK | Soaring | 16 | July 15th 15 01:43 PM |
Grob 103 Ballast Weights | Roger Fowler[_2_] | Soaring | 0 | January 16th 12 12:18 PM |
Who first used water ballast and when? | John McCullagh | Soaring | 9 | October 18th 06 09:36 AM |
