Standard Cirrus 1973 (Grob) no water ballast
Old October 1st 19, 09:43 PM posted to rec.aviation.soaring
Nick Gilbert[_2_]
Default Standard Cirrus 1973 (Grob) no water ballast
As Eric said - definitely Schempp Hirth.
For what it's worth, one of the most well known Standard Cirrii is VH-GZR, flown by Ingo Renner at the 1974 Worlds at Waikerie in Australia, and the subject of the movie "Zulu Romeo, Good Start". This is a Grob build
Cheers,
Nick.
Old October 1st 19, 10:33 PM posted to rec.aviation.soaring
Eric Munk
VH-GZR,
Australia, and the
build
Cheers,
Nick.
Flies very well too, that particular Cirrus.
Old October 2nd 19, 01:49 AM posted to rec.aviation.soaring
JS[_5_]
VH-GZR,
Australia, and the
build
Cheers,
Nick.
Attila makes it go well.
Old October 2nd 19, 09:06 PM posted to rec.aviation.soaring
Ian Simmonds
Cheers,
Nick.
Thanks Nick
I looked this video up on youtube and just watched it — fantastic, loads of Cirri to be seen.
Thanks )
Best
Ian
Old October 9th 19, 05:41 PM posted to rec.aviation.soaring
Ian Simmonds
Just a little update for those that are interested in the 1973 Cirrus without water ballast in the wings.
I had the following email from a Schempp Hirth employee:
Still none the wiser!
Dear Mr. Simmonds,
after checking our drawing list are all of the Standart Cirrus was built with water balast into the wings. I can´t see why you glider was built without water balast.
Mit freundlichen Grüßen / Best regards
René Dank
Kundendienstleitung / Customer Service Direktor
Schempp-Hirth Service GmbH
Krebenstr. 25
73230 Kirchheim unter Teck
Jantar Standard 3 water ballast tank repair [email protected] Soaring 6 June 5th 17 12:25 PM
ASK-21 and Grob 103 cockpit ballast weights kirk.stant Soaring 12 September 2nd 15 08:57 PM
water ballast 6PK Soaring 16 July 15th 15 01:43 PM
Grob 103 Ballast Weights Roger Fowler[_2_] Soaring 0 January 16th 12 12:18 PM
Who first used water ballast and when? John McCullagh Soaring 9 October 18th 06 09:36 AM
