Op vrijdag 4 oktober 2019 15:17:12 UTC+2 schreef Turkey Vultu
I have actually used the s100 in my DG 100 for 1 season. I popped for the AHRS as well. 80mm is the way to go. I ordered the lx navigation Eros first and then returned it. I preferred the simplicity of the S100. I found the era to be slightly less user friendly but it’s basically the same unit. You will be happy with the S100. It has all the bells and whistles and is easy to use. I have it on electronic compensation though and it creates an overly sensitive and optimistic vario. Adjusting internal settings has minimal effect on this. On the DG 100 I would use the traditional TE compensation. I think you need the combo probe to get good performance with electronic compensation on the S100. I find myself waiting on the winter to confirm a thermal before turning. The S100 is usually right about the thermal and quick to identify it, but screams like it’s going to be a 5 kt climb until you exuberantly turn and find it to only be 1.5 kts. Yes, I have tuned it for stick thermals Properly. The winter stays honest throughout. I think this is due to the location of the static holes... The $800 AHRS option sure is cool eye candy and could come in useful on that wave day where it closes in below you but Otherwise, you won’t use it. My last comment is that you have one option for tone. Yea you can adjust it slightly but it’s doesn’t change much. For $2,000 you should have 10 options for types of sounds for the vario. It blows my mind that nobody seems to care and it’s not even discussed in reviews. The tone should be highly adjustable just like the face of the vario. Instead you get a standard beep. Cambridge and Tasman had some nice option. The industry needs to pamper attention to this as we all have to listen to it for hours on end Also, would you say the LX stick is worth it? My DG instrument panel is quite far, I've only used the LX stick for an LX 9070 in an Arcus, and that was quite pleasant. |
![]() Also, would you say the LX stick is worth it? My DG instrument panel is quite far, I've only used the LX stick for an LX 9070 in an Arcus, and that was quite pleasant. I love the LX grip and installed in my my DG400 with the S100. I go the one that has the toggle switch which I worked to raise and lower the engine. Push forward to extend, and pull back to stow engine. Much more intuitive that the side toggle. But the overall function of the stick controller is great and I can toggle form flarm, waypoint, task, pages very simply with my thumb. Also macredy, ballast, bugs, and volume very easily. I Love the stick controller. Kevin Anderson 92 |
On Friday, October 4, 2019 at 9:17:12 AM UTC-4, Turkey Vulture wrote:
I have actually used the s100 in my DG 100 for 1 season. I popped for the AHRS as well. 80mm is the way to go. This is a huge difference between the two brands. LX Nav does not let you revoke the AHRS key, which translated into normal human speak means that you can't take your AHRS with you. So if you sell your unit to someone else because you want LX Nav's latest and greatest, or just your unit conks out, you're SOL for the $$$ you spent. Every time you get a new model you have to spend $800. LX Navigation has a separate AHRS module which is portable to new installations. Frankly, and this is speaking as an embedded guy who's been doing drone autopilot firmware since 2010, LX Nav has destroyed a lot of the value of their product for peeps who want an AHRS. Unless their internal software is a dumpster fire, which is its own problem, fixing this lack of portability is a perfect first task for an intern/junior engineer. |
On Wednesday, 13 May 2020 09:02:28 UTC+1, Kenz Dale wrote:
On Friday, October 4, 2019 at 9:17:12 AM UTC-4, Turkey Vulture wrote: I have actually used the s100 in my DG 100 for 1 season. I popped for the AHRS as well. 80mm is the way to go. This is a huge difference between the two brands. LX Nav does not let you revoke the AHRS key, which translated into normal human speak means that you can't take your AHRS with you. So if you sell your unit to someone else because you want LX Nav's latest and greatest, or just your unit conks out, you're SOL for the $$$ you spent. Every time you get a new model you have to spend $800. LX Navigation has a separate AHRS module which is portable to new installations. Frankly, and this is speaking as an embedded guy who's been doing drone autopilot firmware since 2010, LX Nav has destroyed a lot of the value of their product for peeps who want an AHRS. Unless their internal software is a dumpster fire, which is its own problem, fixing this lack of portability is a perfect first task for an intern/junior engineer. This is a commercial issue not an engineering issue. I believe all these devices have the necessary sensors to provide an AHRS - the payment is for the license to switch it on. I have just upgraded my LX 9000 - I traded in the previous one to LX and paid an upgrade price. Who knows how the cost to upgrade would have compared if I had had an LX Navigation device instead? I know two people who bought LX Navigation LX 10k's. Neither could be got to work and they eventually had to change to something different. This makes me dubious about the product development quality at LX Navigation, whereas I have not heard of problems like that with LX Nav equipment in the last few years. |
Hi,
The LXNAV S8, S80, S10 and S100 variometers are the best varios available. They are well designed and more reliable than any other currently available variometer. The built-in AHRS hardware makes them easy to install and reliable. LXNAV developed the AHRS hardware - they didn't tack-on an external AHRS unit. The varios fully replace older vario systems like the Cambridge 302/303 system, ILEC SN10, etc. They are available in either 57mm or 80mm sizes with exactly the same functionality in either size. And they use a single instrument hole instead of 2. They offer excellent variometer functions as well as waypoint and task navigation, FLARM and ADS-B traffic display and warnings, and final glide calculations. They also have built-in g-meters as standard. Also, with the current exchange rates, you can get an S8-Club speed-to-fly variometer for $870. That is much lower cost than previous speed-to-fly variometers. I also like that you can buy a "club" version with the same hardware and add software features easily at any time in the future. Also, the AHRS enable is a software enable that can be done easily at any time. They work great with FLARM units and Naviter Oudie units too. I very highly recommend them. I do sell them, but I also fly with them. S8, S80, S8-Club, S80-Club https://www.cumulus-soaring.com/stor...product_id=777 S10, S100 https://www.cumulus-soaring.com/stor...product_id=105 Best Regards, Paul Remde Cumulus Soaring, Inc. On Wednesday, May 13, 2020 at 3:02:28 AM UTC-5, Kenz Dale wrote: On Friday, October 4, 2019 at 9:17:12 AM UTC-4, Turkey Vulture wrote: I have actually used the s100 in my DG 100 for 1 season. I popped for the AHRS as well. 80mm is the way to go. This is a huge difference between the two brands. LX Nav does not let you revoke the AHRS key, which translated into normal human speak means that you can't take your AHRS with you. So if you sell your unit to someone else because you want LX Nav's latest and greatest, or just your unit conks out, you're SOL for the $$$ you spent. Every time you get a new model you have to spend $800. LX Navigation has a separate AHRS module which is portable to new installations. Frankly, and this is speaking as an embedded guy who's been doing drone autopilot firmware since 2010, LX Nav has destroyed a lot of the value of their product for peeps who want an AHRS. Unless their internal software is a dumpster fire, which is its own problem, fixing this lack of portability is a perfect first task for an intern/junior engineer. |
LXNAV S100 calibration and firmware question | vtcyclist | Soaring | 18 | May 25th 19 05:42 PM |
Air glide Vario family versus S100 LXNAV - Comments on Winds and Performance? | WaltWX[_2_] | Soaring | 11 | December 17th 18 10:01 AM |
LX S100 | Bryce Sammeter | Soaring | 2 | November 1st 17 08:43 AM |
S80 S100 stick controller how helpful? | [email protected] | Soaring | 11 | February 13th 17 04:03 AM |
