Best Oxygen Setup?
Old October 4th 19, 01:49 AM posted to rec.aviation.soaring
Dan Marotta
Default Best Oxygen Setup?
I've never heard of a dive shop supplying oxygen.Â* During my scuba
training in the early 60s, I was taught that oxygen is toxic at high
ambient pressure as below some depth which I didn't bother to research.Â*
Imagine filling a scuba tank (dive bottle) with oxygen and killing the
diver!
Now I know that things are different on the east side of the Atlantic,
but are you sure you're getting oxygen and not just compressed air at
the dive shop?
On 10/3/2019 2:17 PM, Jonathon May wrote:
At 18:22 03 October 2019, Eric Greenwell wrote:
Jonathon May wrote on 10/3/2019 9:55 AM:
I have been using a Dive type cylinder because they are easier
to
get re filled.
Last Saturday I was flying with the bottle on but the regulator
off
above a ridge trying to connect to the wave system.
About 1 hour in and 2700ft asl there was a loud pop and bottle
pressure O2 started blowing into the cockpit .
I could not turn the bottle off so I opened the DV window put a
Pan call out and got it back on the glider field in about 3
minuets .
I have never been so scared ,and I have loads of field landings
and
thousands of hours in gliders.
I blame it on lack of maintenance and use, the cylinders has
been
sitting in the glider since March turned off while I flew thermals
in
the UK.
My bad just need the bottle re-filling and probably a new O ring.
What is a Dive type cylinder, and why is it easier to get it refilled
with
oxygen?
What failed and caused the pop?
Eric Greenwell - Washington State, USA (change ".netto" to ".us"
to email
me)
https://sites.google.com/site/motorg...ions/download-
the-guide-1
I assume the O ring displaced,I took it off and it sealed OK on the
ground, but its going to be checked before I use it again I assure
you.
Dive cylinder has a square top with an outlet and 2 indexing pins.
The regulator does over the top with a yoke and a screw pushes an
inlet with O ring positioned with the index pins against the outlet.
They are common to compressed air dive bottles ,quick to change
bottles and no chance of a cross thread.Very robust compared with
our threaded connector mountain high cylinders.
In the Uk many dive shops will not charge a DOT cylinder, they want
a DIN number and date.
Dan, 5J
Old October 4th 19, 02:45 AM posted to rec.aviation.soaring
diver!
Divers keep a bottle of O2 around in the boat to treat bends or just to get rid of nitrogen in blood faster to be able to dive more in a day.
Old October 4th 19, 01:23 PM posted to rec.aviation.soaring
RR
Things have changed since you have been diving. Not about the toxicity of O2 at depth (I think at pressures above 2 atmosphere (below 10m)) but the use of pure Ox in diving.
These days there are mixed gas rebreathers. They work by mixing the breathing gas in the system in real time,and removing the co2 fully self contained. So diving with no bubbles. They use high pressure pure Ox to feed the system. Often 3 or 4k psi in small spherical tanks. As you can imagine this is not cheap, and quite technical. Google Mixed Gas Rebreathers if interested.
Old October 5th 19, 01:11 AM posted to rec.aviation.soaring
Dan Marotta
Very cool!
Dan, 5J
LXNav V7 Setup svelusive Soaring 9 February 22nd 15 04:29 PM
A-37 Dragonfly smoke setup Glenn[_4_] Aviation Photos 0 December 27th 12 03:00 AM
Vario setup brianDG303 Soaring 1 April 3rd 08 05:20 PM
FS 2004 setup Dave Hetteen Simulators 4 June 25th 04 10:40 PM
WX Works setup Paul Tomblin Piloting 16 December 8th 03 04:23 AM
