A Different Battery Question
Old October 18th 19, 09:44 AM posted to rec.aviation.soaring
krasw
Default A Different Battery Question
We charged LFP battery installed in glider using charger plug that feeds the battery via glider electrical system. We discovered that there was automatic breaker hidden in glider electrical system (DG DEI) that stole little bit of voltage. This caused charger to not charge battery to full. It seems that you cannot have automatic breakers between charger and battery.
Old October 18th 19, 03:29 PM posted to rec.aviation.soaring
Tim Newport-Peace[_6_]
th=
automa=
b=
seems
Whenever you put any device is series, expect to lose something. For
example with a series diode expect to lose about 0.5volt.
For this reason many radio manufacturers use a back-biased diode across the
supply and a series fuse. In this way no current passes through the diode
unless you cross-polarity the radio, in case it will be a short to blow the
fuse.
Old December 3rd 19, 06:15 AM posted to rec.aviation.soaring
John DeRosa OHM Ω http://aviation.derosaweb.net
KRASW - The voltage loss/drop across a breaker depends on the amp rating of the breaker. The smaller the rating the larger the drop.
For example, a small value 1A Tyco W32 breaker drops ~0.6Vdc. A 1A Klixon 7277 breaker can drop ~1Vdc! I always use a 5A or larger breaker. A clear case of "bigger is better".
See slides #95 for the full story at http://aviation.derosaweb.net/presen..._Made_Easy.pdf.
14v Battery Question. [email protected] Soaring 5 June 6th 15 02:40 AM
Garmin 396 battery question Paul kgyy Piloting 2 November 16th 07 05:13 PM
Battery Question mbremer216 Owning 7 October 6th 06 10:16 PM
Yet Another Battery Question P. Corbett Soaring 5 April 26th 06 02:22 AM
Battery Question [email protected] Soaring 19 September 15th 05 01:38 AM
