Jonker JS4 Details
Old October 18th 19, 10:32 AM posted to rec.aviation.soaring
Andy Blackburn[_3_]
Default Jonker JS4 Details
JS4 has a retractable electric motor instead of FES and it can self launch.
“The JS4 will be available with the jet sustainer system as well as the new electric self-launch motor option which retracts into the fuselage for low-drag ultimate performance.“
Getting some extra mileage out of all that fuselage and wing work on the JS3. I’m guessing the electric motor might go in the JS3 as well unless the flap mixer gets in the way since it’s otherwise the same fuselage. They had been talking FES previously as an option for the JS3.
All that leaves is a high-performance two-seater - unless they want to try to crack the trainer market.
Admirable efforts.
Andy Blackburn
Old October 18th 19, 11:08 AM posted to rec.aviation.soaring
Paul T[_4_]
launch.
=E2=80=9CThe JS4 will be available with the jet sustainer system
as well
as=
fuselage=
for low-drag ultimate performance.=E2=80=9C
on the
JS=
3. I=E2=80=99m guessing the electric motor might go in the JS3
as well
unle=
ss the flap mixer gets in the way since it=E2=80=99s otherwise
the same
fus=
JS3.=20
to try
Admirable efforts.
Andy Blackburn
A JS5 is listed as a product coming in 2024?????
Old October 18th 19, 03:41 PM posted to rec.aviation.soaring
What do they have for 13.5 M ?
Old October 18th 19, 03:47 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Admirable efforts.
Andy Blackburn
I would love to see Jonker's original thought on high performance two place.. And if you haven't shared a flight in a high performance two place you should put that on your list. My funnest flights have been in one hole of an open two holer.
Old October 18th 19, 04:04 PM posted to rec.aviation.soaring
Dave Nadler
Yea, I used to fly my RHJ-8 open-canopy too...
Old October 18th 19, 06:59 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
The RHJ-9 flew open canopy once, too. The flight before I got it. Needed some repairs. But, that was because it started the flight with the canopy on in the normal position, and ended the flight with the canopy "on" but in a not at all normal position (stuck to the tail).
Steve Leonard
Jonker JS-3 in Sagebrush [email protected] Soaring 37 April 23rd 19 01:08 PM
Jonker JS-1 fatality in SA 20 Jan [email protected] Soaring 3 January 29th 14 08:20 PM
FAR 61.58 regarding HpH 304SJ,Jonker JS1-CJT, et al jet sustainers [email protected] Soaring 2 May 23rd 13 04:52 PM
Jonker Revalation ( JS -1 ) [email protected] Soaring 1 August 7th 10 12:03 PM
Jonker 18 meter sailplane Greg Arnold Soaring 4 November 4th 06 02:15 AM
