Oops, dye penetrant testing, damn auto carrot. if you didn’t do due test, you don’t really know if cracks went further or not.
The cracking had only effected the epoxy matrix, but the glass had to be removed to fix them From Schlesinger tech note: As all the outside skin of the aircraft is dimensioned for stiffness, there are no critical mechanical strength problems, even if some cracks have gone down into the fiber composite structure and have already attacked the resin matrix base. The unknown ageing effects caused by the influence of moisture and UV on the unprotected fiber composite structure are more dangerous. |
Gel coat removal - is this okay?!? | Kevin Christner | Soaring | 13 | July 10th 15 03:44 PM |
Gel coat inspection | Matt Keast[_2_] | Soaring | 12 | October 26th 07 09:14 PM |
Gel Coat Question | Gary Emerson | Soaring | 2 | September 12th 07 11:56 AM |
Gel Coat for Dummies | Ray Lovinggood | Soaring | 12 | December 24th 04 01:12 AM |
Gel Coat for Dummies | Ray Lovinggood | Soaring | 2 | December 12th 04 08:15 PM |
