FAI Annex A rules (which are undergoing massive change) do not drive pilots to land out. Many WGCs and EGCs are run in eastern Europe and gliding/competition culture there is different. It is common to set task to sky that is totally dead. First turnpoint or even start point in steady rain? No problem, just go. And then we have 130 outlandings.
We have run nationals using Annex A for decades with very little problem of outlandings. Usually AAT is set on trickier days and if it's raining, we do not feel obliged to fly. It is very convenient to blame rulebook for bad task setting. I should add that proposed scoring change to Annex A (by USA) creates MASSIVE incentive to scratch home over the last trees and creates a huge outlanding risk. If I'm not wrong the same people here complaining the risk level introduced by Annex A rules actually drafted that proposal. |
At 07:14 30 October 2019, krasw wrote:
I should add that proposed scoring change to Annex A (by USA) creates MASSIVE incentive to scratch home over the last trees and creates a huge out landing risk. There is already a strong incentive to scratch home and pretty much everyone I fly against in the UK 15s would do so anyway. I like the proposal as it simplifies the scoring rules. Sensible pilots will choose a flat landable field before the line that can be used safely if they cannot make the hedge. In circumstances where there is a finish ring the decision to land will probably be made higher and with reduced risk. Landing out is a integral part of competition flying in gliders. We train for it and do it regularly. If you fly a motor glider (dig) then you probably are less current and more at risk when the engine doesn't behave. Jim |
On Wednesday, October 30, 2019 at 12:15:07 PM UTC+2, Jim White wrote:
At 07:14 30 October 2019, krasw wrote: I should add that proposed scoring change to Annex A (by USA) creates MASSIVE incentive to scratch home over the last trees and creates a huge out landing risk. There is already a strong incentive to scratch home and pretty much everyone I fly against in the UK 15s would do so anyway. I like the proposal as it simplifies the scoring rules. Sensible pilots will choose a flat landable field before the line that can be used safely if they cannot make the hedge. In circumstances where there is a finish ring the decision to land will probably be made higher and with reduced risk. Landing out is a integral part of competition flying in gliders. We train for it and do it regularly. If you fly a motor glider (dig) then you probably are less current and more at risk when the engine doesn't behave.. Jim If you are the one out of 50 pilots who gets home and others land out on the last field next to finish line, current scoring gives you maybe ten point spread over pilots landing out. Proposed scoring would increase this to 250 points (devaluation scheme applies to both, depending on the day). In my opinion the incentive is not the same. |
On Wednesday, October 30, 2019 at 8:55:15 AM UTC-4, krasw wrote:
On Wednesday, October 30, 2019 at 12:15:07 PM UTC+2, Jim White wrote: At 07:14 30 October 2019, krasw wrote: I should add that proposed scoring change to Annex A (by USA) creates MASSIVE incentive to scratch home over the last trees and creates a huge out landing risk. There is already a strong incentive to scratch home and pretty much everyone I fly against in the UK 15s would do so anyway. I like the proposal as it simplifies the scoring rules. Sensible pilots will choose a flat landable field before the line that can be used safely if they cannot make the hedge. In circumstances where there is a finish ring the decision to land will probably be made higher and with reduced risk. Landing out is a integral part of competition flying in gliders. We train for it and do it regularly. If you fly a motor glider (dig) then you probably are less current and more at risk when the engine doesn't behave. Jim If you are the one out of 50 pilots who gets home and others land out on the last field next to finish line, current scoring gives you maybe ten point spread over pilots landing out. Proposed scoring would increase this to 250 points (devaluation scheme applies to both, depending on the day). In my opinion the incentive is not the same. Provides incentive to fly your own race, yes. That's a good thing. T8 |
Or skip that last good field or airport to try and cross the finish for that 250 pt incentive...
There are going to be pros and cons to every situation. I think we should expect competition directors to set a fair and reasonable task based on current weather and from that point it should be up to the pilot in command to make their decision from that point on. Soaring is not the safest sport out there but is comparable to motorcycles. If you respect it, your safety and that of those involved goes up significantly compared to the guy flying by at 120 mph without a helmet. The majority of pilots again voted to begin implementing FAI rules at US Nationals and I don’t see any increased risk having flown both versions. |
On Wednesday, October 30, 2019 at 1:19:27 PM UTC-4, wrote:
Or skip that last good field or airport to try and cross the finish for that 250 pt incentive... ....which is why there is something to be said for a sane minimum finish height. T8 |
Which is available and used under FAI rules for finishes.
On Wednesday, 30 October 2019 15:40:58 UTC+1, Tango Eight wrote:
On Wednesday, October 30, 2019 at 8:55:15 AM UTC-4, krasw wrote: On Wednesday, October 30, 2019 at 12:15:07 PM UTC+2, Jim White wrote: At 07:14 30 October 2019, krasw wrote: I should add that proposed scoring change to Annex A (by USA) creates MASSIVE incentive to scratch home over the last trees and creates a huge out landing risk. There is already a strong incentive to scratch home and pretty much everyone I fly against in the UK 15s would do so anyway. I like the proposal as it simplifies the scoring rules. Sensible pilots will choose a flat landable field before the line that can be used safely if they cannot make the hedge. In circumstances where there is a finish ring the decision to land will probably be made higher and with reduced risk. Landing out is a integral part of competition flying in gliders. We train for it and do it regularly. If you fly a motor glider (dig) then you probably are less current and more at risk when the engine doesn't behave. Jim If you are the one out of 50 pilots who gets home and others land out on the last field next to finish line, current scoring gives you maybe ten point spread over pilots landing out. Proposed scoring would increase this to 250 points (devaluation scheme applies to both, depending on the day). In my opinion the incentive is not the same. Provides incentive to fly your own race, yes. That's a good thing. T8 Ok, picture this. Weather is weak dry thermals to 2000ft. You have a long task to fly. The pilot who gets home collects the 250p award. There is 50 pilots flying the same task in ****ty weather. And your tactic would be "to fly your own race"? |
On Thursday, October 31, 2019 at 2:19:51 AM UTC-4, krasw wrote:
On Wednesday, 30 October 2019 15:40:58 UTC+1, Tango Eight wrote: On Wednesday, October 30, 2019 at 8:55:15 AM UTC-4, krasw wrote: On Wednesday, October 30, 2019 at 12:15:07 PM UTC+2, Jim White wrote: At 07:14 30 October 2019, krasw wrote: I should add that proposed scoring change to Annex A (by USA) creates MASSIVE incentive to scratch home over the last trees and creates a huge out landing risk. There is already a strong incentive to scratch home and pretty much everyone I fly against in the UK 15s would do so anyway. I like the proposal as it simplifies the scoring rules. Sensible pilots will choose a flat landable field before the line that can be used safely if they cannot make the hedge. In circumstances where there is a finish ring the decision to land will probably be made higher and with reduced risk. Landing out is a integral part of competition flying in gliders. We train for it and do it regularly. If you fly a motor glider (dig) then you probably are less current and more at risk when the engine doesn't behave. Jim If you are the one out of 50 pilots who gets home and others land out on the last field next to finish line, current scoring gives you maybe ten point spread over pilots landing out. Proposed scoring would increase this to 250 points (devaluation scheme applies to both, depending on the day). In my opinion the incentive is not the same. Provides incentive to fly your own race, yes. That's a good thing. T8 Ok, picture this. Weather is weak dry thermals to 2000ft. You have a long task to fly. The pilot who gets home collects the 250p award. There is 50 pilots flying the same task in ****ty weather. And your tactic would be "to fly your own race"? In USA, we will not launch if the top of lift is 2000'. T8 |
On Thursday, 31 October 2019 14:21:59 UTC+2, Tango Eight wrote:
On Thursday, October 31, 2019 at 2:19:51 AM UTC-4, krasw wrote: On Wednesday, 30 October 2019 15:40:58 UTC+1, Tango Eight wrote: On Wednesday, October 30, 2019 at 8:55:15 AM UTC-4, krasw wrote: On Wednesday, October 30, 2019 at 12:15:07 PM UTC+2, Jim White wrote: At 07:14 30 October 2019, krasw wrote: I should add that proposed scoring change to Annex A (by USA) creates MASSIVE incentive to scratch home over the last trees and creates a huge out landing risk. There is already a strong incentive to scratch home and pretty much everyone I fly against in the UK 15s would do so anyway. I like the proposal as it simplifies the scoring rules. Sensible pilots will choose a flat landable field before the line that can be used safely if they cannot make the hedge. In circumstances where there is a finish ring the decision to land will probably be made higher and with reduced risk. Landing out is a integral part of competition flying in gliders. We train for it and do it regularly. If you fly a motor glider (dig) then you probably are less current and more at risk when the engine doesn't behave. Jim If you are the one out of 50 pilots who gets home and others land out on the last field next to finish line, current scoring gives you maybe ten point spread over pilots landing out. Proposed scoring would increase this to 250 points (devaluation scheme applies to both, depending on the day).. In my opinion the incentive is not the same. Provides incentive to fly your own race, yes. That's a good thing. T8 Ok, picture this. Weather is weak dry thermals to 2000ft. You have a long task to fly. The pilot who gets home collects the 250p award. There is 50 pilots flying the same task in ****ty weather. And your tactic would be "to fly your own race"? In USA, we will not launch if the top of lift is 2000'. T8 Your arguments are so rock solid that I concede. |
USA Pilot Opinion Poll and Rules Committee Election Ends Sunday (Oct 18) | John Godfrey (QT)[_2_] | Soaring | 0 | October 18th 15 03:09 AM |
USA Pilot Opinion Poll and Rules Committee Election Starts Now | John Godfrey (QT)[_2_] | Soaring | 1 | October 17th 15 07:49 PM |
US Contest Rules Pilot Poll | [email protected] | Soaring | 6 | October 15th 12 07:12 PM |
US Competition Pilot Poll and Rules Committee Election Now Open | John Godfrey (QT)[_2_] | Soaring | 1 | September 30th 11 02:59 PM |
US SSA Contest Pilot Opinion Poll | Ken Sorenson | Soaring | 19 | October 6th 10 07:03 PM |
