Pawnee TOST Hook Installation FAA Paperwork
Old November 10th 19, 02:35 AM posted to rec.aviation.soaring
Bob Youngblood
Default Pawnee TOST Hook Installation FAA Paperwork
On Saturday, November 9, 2019 at 8:55:51 AM UTC-5, Charles Longley wrote:
I guess the only real advantage of having a standard airworthiness certificate is you could do what you want with the airplane when you’re not towing. Take a restricted Pawnee into Johnson Creek and hang out with the Super Cub guys. FAA might take a dim view.
The FAA could care less about taking a restricted class plane into Johnson Creek. Many other types of planes come to the fly-in other than super cubs. From my experiences most all super cub fliers would love to fly the Pawnee..
Old November 10th 19, 03:41 AM posted to rec.aviation.soaring
Charles Longley
Yeah so I guess you make my point. It’s advantageous to have a Pawnee with a standard airworthiness certificate as opposed to restricted. Who knows what the FAA would do. I have a bunch of experience in Super Cubs and Pawnees by the way. The Pawnee is far easier to fly and has that awesome O540! I am dreaming about how to stuff it into a Super Cub.
Old November 10th 19, 04:20 AM posted to rec.aviation.soaring
Dan Marotta
Look up Mike Patey and his Carbon Cub rebuild with the 8-cylinder Lycoming.
Dan, 5J
Old November 10th 19, 03:01 PM posted to rec.aviation.soaring
Charles Longley
I can’t find it. Mike Patey does some pretty cool stuff! Bummer on Draco.
I wonder if an O540 is practical in a Super Cub?
Old November 11th 19, 05:15 PM posted to rec.aviation.soaring
Dan Marotta
Start HERE https://www.youtube.com/watch?v=zYkDRiEnYwA and rummage
around.Â* Or just look for "Scrappy" on youtube and start from the
beginning on the design philosophy.
Dan, 5J
Old November 10th 19, 11:11 AM posted to rec.aviation.soaring
Bob Youngblood
Good morning Charlie, can you please explain why the restricted category is such a disadvantage. I have owned three Pawnee's, flew the Super Cub for many years, I really would like to understand your reasoning.
Old November 10th 19, 02:29 PM posted to rec.aviation.soaring
Charles Longley
Good morning Bob. From a club standpoint it probably doesn’t make much difference. From a possible personal airplane that you let out for towing it would make difference. Restricted means just that. Towing glider or whatever the restriction is, ferry flights, training flights, etc. Look at 91.313
Standard Airworthiness certificate with a 337 for the tow hook is a reasonable route to go.
Old November 10th 19, 11:57 PM posted to rec.aviation.soaring
Bob Youngblood
Good evening Charlie, it actually is up to the FSDO to determine if they want to change the restriction application. Some of them just leave them the way they were and do not worry about changing the restriction classification. Why change it?? Are you planning on teaching in the PAwnee, that would be very uncomfortable. There is no provision that states that you cannot fly the Pawnee anywhere you wish, I have had a couple of mine into some pretty big airports and never had an inspector ask me what I was spraying.
Keeping the Pawnee in the restricted category brings about many benefits. Bob
Old November 11th 19, 12:37 AM posted to rec.aviation.soaring
Charles Longley
Evening Bob,
What are the benefits of staying in the restricted category? I am really curious. All 3 of the Pawnees I fly have a standard airworthiness certificate.
Regards,
Charlie
Old November 11th 19, 08:13 AM posted to rec.aviation.soaring
Bob Youngblood
On Sunday, November 10, 2019 at 7:37:05 PM UTC-5, Charles Longley wrote:
Evening Bob,
Regards,
Charlie
Early morning Charlie, Export and import paperwork and cost, Maintenance cost IA vs AP, and making changes in things that do not change design. power or thrust. Another benefit is noise abatement restrictions or lack of.
Looking to buy Tost hook [email protected] Soaring 2 March 4th 17 01:02 PM
Tost tow hook STC for C-182 ? [email protected] Soaring 6 September 27th 16 01:13 AM
needed!! drawings/data for Tost hook for Pawnee thing73 Soaring 3 November 13th 09 02:14 AM
Cessna 185 with a Tost hook? Nimbob Soaring 1 September 29th 09 12:43 PM
Tost hook on Cessns 180 Paul Soaring 6 October 18th 04 10:32 PM
