Put your money where the risk is
Old November 29th 19, 02:39 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Default Put your money where the risk is
2G wrote on 11/28/2019 7:49 PM:
On Thursday, November 28, 2019 at 7:23:16 PM UTC-8, Eric Greenwell wrote:
2G wrote on 11/28/2019 4:50 PM:
When someone once told me that I was lucky in life, I replied "I make my own luck."
This is, I think, an example of thinking that can lead to an erosion of margins.
If you soar, you are exposed to things like weather and other pilots that you do
not completely control. I think "stuff happens" and the best I can do is adjust my
margins so that my skill can cope with bad stuff.
Hardly, what it means is that you are proactively, instead of passively, involved in all things that effect your life and business. So, this means INCREASING your margins on glide calculations, or NOT flying in iffy weather, rather than depending upon "luck" to get you thru as Masak did. The entire point is NOT depending upon "luck" which is a euphemism for ****-poor planning. You can't control everything that is happening around you, but you can as best prepared as humanly possible.
Neither Ramy, Dale, or I depend on luck to protect us, and I very much doubt that
Peter did either. I know/knew all these guys, and I and they do/did exactly as you
recommend. Your "You can't control everything that is happening around you" is
what we are calling "luck".
Old November 29th 19, 03:36 PM posted to rec.aviation.soaring
I agree, but one has to draw a useful lesson.
Consider BlackJack with card counting. Definitely luck is involved because the cards are still random. Skill is involved to be able to understand the situation and choose when and how to play. Applying this skill allows one to manipulate the odds so that there will likely be a favorable outcome. Does this not qualify as "making your own luck"?
Airplane flying requires knowledge and good judgment in choosing when, where, and how to fly. I can appreciate that there is a great deal of this separating old from bold pilots.
Performance soaring has the added random in that you are also dependent on the micro weather as a lift source. You deal with this by putting yourself in the best position to gather energy, hopefully while still accomplishing your task, but always remembering that things are unlikely to work out exactly as expected, so you are continually adjusting.
So for the final glide example, you do your best to setup a final glide, but if you hit continual sink, then move over to get out of the sink street quickly and into the lift street. If that doesn't work, you might be able to circle before getting too low. If that doesn't work, then you should have landing options near the airport. Continuing a deteriorating glide hoping that some unknown will prevent you from having to make your own luck seems one of those 'let us not do that again' things that makes good judgment.
Old November 29th 19, 05:55 PM posted to rec.aviation.soaring
2G
Consider BlackJack with card counting. Definitely luck is involved because the cards are still random. Skill is involved to be able to understand the situation and choose when and how to play. Applying this skill allows one to manipulate the odds so that there will likely be a favorable outcome.. Does this not qualify as "making your own luck"?
Yes, developing black jack skills is an example of "making your own luck."
I once retrieved a guy who damaged his glider landing out in the Nevada desert sagebrush (they really aren't brush, but actually are small trees). He had a perfectly landable farmer's field on the other side of the valley, but chose to waste his valuable altitude looking for elusive lift. Obviously, this was a bad decision by the pilot that was totally avoidable. In this case, he made his own BAD luck.
People use "bad luck" instead of admitting to poor judgment. To paraphrase, luck is not a strategy, good planning and execution is.
Tom
Gliding risk.... [email protected] Soaring 141 December 11th 19 05:25 PM
YOUR safety is at risk BR549 Instrument Flight Rules 0 December 13th 07 12:21 AM
Safety at risk in FAA Peterpan Piloting 7 February 24th 05 08:58 PM
how much money have you lost on the lottery? NOW GET THAT MONEY BACK! shane Home Built 0 February 5th 05 07:54 AM
U.S. SCHOOLKIDS AT RISK Cribsheet Piloting 0 December 5th 04 05:29 PM
