#31
Everything I've flown with a squat switch (props, turboprops, jets) has
had shock struts.Â* Does the '20 have one of those? Come to think of it, we use "landing gear down and locked" as a position for a micro switch in our gear warning systems.Â* It shouldn't be at all difficult to use a micro switch in the "landing gear up and locked" position as your "in flight" sensor.Â* But when you lower the gear, you'll be reporting "on ground".Â* You could also use a toggle switch, just don't forget to flip it.Â* Or you could simply switch your transponder from ON to ALT before takeoff and after landing. On 11/28/2019 4:30 PM, Charles Longley wrote: I am thinking about a better mousetrap. Probably can’t do a squat switch on the gear because of the configuration on the ASW20. But I’ll think it over. -- Dan, 5J |
#32
Yeah I am familiar with how a squat switch works. There’s no suspension in an ASW-20 except the tire so no place to put the squat switch. I’ll take a look at it when I do the Condition Inspection. Maybe something will come to me.
#33
On Friday, November 29, 2019 at 5:58:13 PM UTC-8, Charles Longley wrote:
Yeah I am familiar with how a squat switch works. There’s no suspension in an ASW-20 except the tire so no place to put the squat switch. I’ll take a look at it when I do the Condition Inspection. Maybe something will come to me. Can anyone show me the FAA regulation that requires a squat switch in a glider? |
#34
There’s no requirement. The issue is if you get down to a low ground speed in flight the transponder might go into the ground mode. I think it’s getting a little overblown on RAS. Trig recommends a squat switch to compensate for it. Some of the other transponder manufactures can compensate for it by programming. I haven’t put a squat switch in any of the power airplanes I’ve installed ADS-B transponders in.
#35
On Friday, November 29, 2019 at 9:25:29 PM UTC-8, Charles Longley wrote:
There’s no requirement. No requirement for a squat switch explicitly, but there is a (not very clear) requirement for some form of automatic air/ground switching for 2020 compliance and you should want to use something that uh actually works reliably. See my tenth post in this thread. The issue is if you get down to a low ground speed in flight the transponder might go into the ground mode. I think it’s getting a little overblown on RAS. Trig recommends a squat switch to compensate for it. Some of the other transponder manufactures can compensate for it by programming. I haven’t put a squat switch in any of the power airplanes I’ve installed ADS-B transponders in. Oh Jesus, yes but none of the aircraft you have installed ADS-B out in are gliders that fly in mountain wave. Nothing of what you have done in those power aircraft installs is relevant here. The other transponder manufactures do not just "compensate for this by programming". I've got a pretty good understanding of GPS technology and I have no clue how this would be possible. You have no way of knowing that Garmin or other systems that use GPS detected ground speed to switch from air/ground will work in scenarios where those aircraft have near zero groundspeed without problems. A GPS in a glider or any other aircraft hovering in strong enough wave with a near zero ground speed just can't work out if it is on the ground or not. That you don't read about this in Garmin or other install documentation is likely only because those aircraft don't fly in strong enough wave/headwinds to have this problem. Again we known for several years now this is a problem for gliders in mountain wave. Especially if your glider is going to fly in wave or strong headwinds please pay attention and get this right with a pneumatic pitot switch. Personally I'd install it that way in every glider, because you just don't know where it will end up flying. Again if you are installing TABS just set the transponder squat switch to "None" and use manual ON/ALT switching on the transponder. The very worse thing you can do in a glider that has any chance of being in mountain wave or a strong headwind is select GPS based air/ground switching. If 91.227 did not imply automatic switching was required you would be better off choosing none and just relying on the ON/ALT switch on the transponder. |
#36
On Friday, November 29, 2019 at 8:45:37 PM UTC-8, wrote:
On Friday, November 29, 2019 at 5:58:13 PM UTC-8, Charles Longley wrote: Yeah I am familiar with how a squat switch works. There’s no suspension in an ASW-20 except the tire so no place to put the squat switch. I’ll take a look at it when I do the Condition Inspection. Maybe something will come to me. Can anyone show me the FAA regulation that requires a squat switch in a glider? You are repeating yourself. I answered this same question from you in the tenth post of this thread. Have regulations change since then? You may not agree with the reasoning there, I think it's *awfully* written FWTW, but I'm pointing out this is the interpretation used in the avionics industry. I also think it was an bad idea for the FAA to require this for light aircraft and I wish they had left that with the RTCA DO-260 standard of not requiring light aircraft to transmit in ground mode at all (continue transmitting ADS-B airborne messages on on the ground). |
#37
Darryl Ramm wrote on 11/29/2019 10:36 PM:
Again if you are installing TABS just set the transponder squat switch to "None" and use manual ON/ALT switching on the transponder. I might forget to switch it correctly. Would using the "gear is down" switch to change between ground/airborne be a sensible choice? The pattern (and the first 500'-1000' after the takeoff) would be flown showing the glider was on the ground, of course, but that might be better than having the whole flight showing as on the ground. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 |
#38
#39
#40
On Saturday, November 30, 2019 at 12:45:34 AM UTC-6, Darryl Ramm wrote:
On Friday, November 29, 2019 at 8:45:37 PM UTC-8, wrote: On Friday, November 29, 2019 at 5:58:13 PM UTC-8, Charles Longley wrote: Yeah I am familiar with how a squat switch works. There’s no suspension in an ASW-20 except the tire so no place to put the squat switch.. I’ll take a look at it when I do the Condition Inspection. Maybe something will come to me. Can anyone show me the FAA regulation that requires a squat switch in a glider? You are repeating yourself. I answered this same question from you in the tenth post of this thread. Have regulations change since then? You may not agree with the reasoning there, I think it's *awfully* written FWTW, but I'm pointing out this is the interpretation used in the avionics industry. I also think it was an bad idea for the FAA to require this for light aircraft and I wish they had left that with the RTCA DO-260 standard of not requiring light aircraft to transmit in ground mode at all (continue transmitting ADS-B airborne messages on on the ground). Having had a trig 2020 compliant ADS-B out system installed in my Standard type certificated glider, I found the peregrine pneumatic switch elegant, compact, cheap, and reliable. not to mention readily available and acceptable to the documentation requirements. I also understand the deep desire some have to 'invent a better mousetrap' Good lift, Scott |
Are air filters necessary on Pitot, static or TE lines? | Pete[_9_] | Soaring | 15 | December 18th 18 02:13 AM |
Pitot Static 411 413 followup post | A Lieberman | Owning | 12 | June 18th 05 04:00 PM |
My static system had a leak | Derrick Early | Instrument Flight Rules | 1 | August 25th 04 02:35 PM |
pitot/static location | Ray Toews | Home Built | 2 | December 30th 03 12:52 AM |
Pitot and static couplings for a TTU-205 | B2431 | Home Built | 0 | August 15th 03 07:25 AM |
