My static system had a leak
Old August 24th 04, 10:14 PM
Derrick Early
Default My static system had a leak
A little while ago I asked if the VSI, altimeter and airspeed instruments
should jump when closing the door. The answer is that they should not. We
had our static system tested and the mechanic found a leak. As a result, we
were getting cabin pressure for altitude our altitude readings. I think
that I'll add this to the check list.
Cheers,
Derrick
Old August 25th 04, 02:35 PM
James M. Knox
"Derrick Early" wrote in
instruments should jump when closing the door. The answer is that
they should not. We had our static system tested and the mechanic
found a leak. As a result, we were getting cabin pressure for
altitude our altitude readings. I think that I'll add this to the
check list.
You were probably getting something between the two - meaning you were
probably flying a little high.
In Piper aircraft there is that little pilot vent window. Makes a good
leak test - at altitude open it and then let it pop shut. If the needles
jump, you've got a leak.
ADF static? question JFLEISC Home Built 3 December 28th 04 01:28 AM
Is my static port leaking? Derrick Early Instrument Flight Rules 2 August 15th 04 01:13 AM
Paint system Sam Fly Home Built 9 December 2nd 03 12:47 AM
FA: halon fire ext system for homebuilts N329DF Home Built 0 August 16th 03 03:12 PM
2nd update on Review of Plasma II Ignition System MikeremlaP Home Built 8 July 22nd 03 01:37 AM
