Corvair conversion engines
Old December 1st 19, 02:23 AM posted to rec.aviation.homebuilt
Default Corvair conversion engines
On Wednesday, January 18, 2006 at 1:19:06 PM UTC-6, Cal Vanize wrote:
As my research continues, I have been investigating possible engines for
a 601XL. The Corvair engines looked like a good candidate. The reports
seemed very good and the engine was surprisingly inexpensive for initial
purchase and long-term maintenance.
The stated expected TBO is 1500 hours and the Corvair Authority website
documents the use of a Corvair engine in a 601XL.
Everything seemed OK until yesterday when I read the most recent updates
on their website. Seems that the "untreated" automotive cranks have
been cracking in a very short time. Nitriding seems like the only
solution. But with standard cranks cracking at under 100 hours, what
would be the expected life of a nitrided crank. Twice as long, four
times as long, eight times as long? This would still fall short of the
1500 hour TBO stated by the Corvair Authority.
Does anyone have any first hand experience with Corvair conversion
engines? Any info on their realistic life and reliability?
TIA,
CV
It seems that no one on this thread has heard of the 5th bearing. The factory crank is a forged steel crank. It is not cast. The 5th bearing has eliminated the broken crank. The broken crank usually only happened on engines that were not used as intended.
Book Review: Converting Auto Engines for Experimental Aircraft , Finch Paul Home Built 0 October 18th 04 11:14 PM
P-3C Ditches with Four Engines Out, All Survive! Scet Military Aviation 6 September 27th 04 02:09 AM
What if the germans... Charles Gray Military Aviation 119 January 27th 04 12:20 AM
Corvair Engine Conversion Breakin Success Dick Home Built 1 January 11th 04 03:06 PM
Corvair Conversion Gig Giacona Home Built 17 October 27th 03 10:43 PM
