Updating Avionics - How I Remember What's What!
Old December 1st 19, 03:31 PM posted to rec.aviation.soaring
Tom BravoMike
Default Updating Avionics - How I Remember What's What!
On Saturday, November 30, 2019 at 11:47:35 PM UTC-6, 2G wrote:
On Tuesday, October 29, 2019 at 8:13:31 AM UTC-7, John DeRosa OHM Ω http://aviation.derosaweb.net wrote:
Updating files/firmware on my avionics should be easy. Then why is it so hard?
Heck, I am an electrical engineer. I have been around computers since high school (early 70's). I was in Information Technology for MANY years and still do this on a volunteer basis. I should be able to handle this!
I think that the answer is in several parts;
- There are multiple files for each device to upload/download; firmware, waypoint databases, FLARM databases, obstacle databases, SUA databases, IGC files, etc, etc.
- What is the URL to find these much needed files?
- Each device seems to need its own specifically formatted file - just look at the turnpoint database! Some instruments are mentioned there by name but others use a "generic" format of a file - but which one to use?
- There are multiple methods to upload/download. With a cable? Via a memory stick? Then where does the file go on the stick (root or a folder)? Does the install happen when the device is booted or when the device is already on? Does the install happen automatically or do you have to manually do something?
- While the avionics manufacturers create wonderful devices it is a fact of life that their manuals seem woefully inadequate for the task at hand and/or become obsolete from lack of updating.
- Is my recorder's re-calibration due so I don't miss getting credit for my epic flight?
- And critically, I only perform this task about once a year and I FORGET the magic steps of what to do!
HELP!
As my own panel evolved from "steam gauges" to a "glass cockpit" I kept my sanity by creating a spreadsheet of the how-tos, where-froms and the tricks-of-the-trade.
BOTTOM LINE: If you are interested in using my spreadsheet as a template for your own cockpit it can be found here = http://aviation.derosaweb.net/forms/
Comments welcome.
Best of Luck,
John OHM Ω
Yeah, it's a quagmire out there, for sure. I went to a full glass cockpit in my new ASH31Mi. I simplified the problem by sticking to three instrument manufacturers: LXNAV, Garmin and Trig. LXNAV provided the glide computer (LX9070), which has a good user's group. I will add their wi-fi adapter next year so I don't have to deal with SD cards. Garmin provided the PFD (primary flight display), which replaced all of the old steam gauges. Trig provided the radio and transponder, and solved the ADS-B out issue. I also had Schleicher install all of the instruments, and they did a GREAT job. This isn't an option for you, so it is either a DYI job or find an avionics shop. I also switched to LFP batteries with a total of 32 AHr of capacity. This is a MUST for a glass cockpit as my typical current draw is 1.9 A. BTW, I also have PowerFlarm, but I don't call that an instrument.
I have flown with this setup for an entire season and LOVE IT! About the only thing I might add is a dedicated Flarm display.
Tom
Any pictures, please?
Old December 13th 19, 04:11 PM posted to rec.aviation.soaring
2G
HELP!
Comments welcome.
Best of Luck,
John OHM Ω
Yeah, it's a quagmire out there, for sure. I went to a full glass cockpit in my new ASH31Mi. I simplified the problem by sticking to three instrument manufacturers: LXNAV, Garmin and Trig. LXNAV provided the glide computer (LX9070), which has a good user's group. I will add their wi-fi adapter next year so I don't have to deal with SD cards. Garmin provided the PFD (primary flight display), which replaced all of the old steam gauges. Trig provided the radio and transponder, and solved the ADS-B out issue. I also had Schleicher install all of the instruments, and they did a GREAT job. This isn't an option for you, so it is either a DYI job or find an avionics shop.. I also switched to LFP batteries with a total of 32 AHr of capacity. This is a MUST for a glass cockpit as my typical current draw is 1.9 A. BTW, I also have PowerFlarm, but I don't call that an instrument.
Tom
Here you go:
https://www.flickr.com/photos/765972...57712179805181
Tom
Old December 13th 19, 07:24 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
2G wrote on 12/13/2019 8:11 AM:
Tom
Here you go:
Looks different! Is the lower vario (S8?) operating independently of the 9070,
what do you usually have displayed on it, and why is it in m/s?
Are you using ADSB-in for anything?
Can you control the radio from the 9070?
Old December 14th 19, 04:25 AM posted to rec.aviation.soaring
2G
Tom
Here you go:
The upper vario is the S8, the lower one the S10.
Everything is now in kts (this was the 2nd flight). The S8 is slaved to the 9070. I could control the radio from the 9070, but that requires a $240 bridge (LXNAV-Bridge-Trig).
I don't have ADS-B In.
Tom
Old December 14th 19, 04:18 PM posted to rec.aviation.soaring
Dan Marotta
Tom
Really???Â* How much have you got invested in that well set up ASH-31?Â*
What's $240 as a percentage of that, 0.1%?
How could anyone claim that glider pilots are notoriously cheap? :-D
Dan, 5J
Old December 14th 19, 05:27 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Dan Marotta wrote on 12/14/2019 8:18 AM:
Tom
Really???* How much have you got invested in that well set up ASH-31? What's $240
I really like the ADSB-in on my Phoenix. The radar and TFRs are worth it; also,
getting the winds and weather at airports out of AWOS range.
Old December 14th 19, 05:45 PM posted to rec.aviation.soaring
I get all that from Foreflight on my iphone
Old December 14th 19, 07:58 PM posted to rec.aviation.soaring
Dan Marotta
Me, too!Â* What Eric said.
Tom
it; also, getting the winds and weather at airports out of AWOS range.
Dan, 5J
Old December 14th 19, 06:43 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Tom
Dan, 5J
One of my favorites was about 2015 someone equipping a brand-new glider was complaining about the Mark IV being a dollar or two more expensive from a reseller than direct from Bumper. Sheesh
Old December 14th 19, 07:14 PM posted to rec.aviation.soaring
2G
Tom
Dan, 5J
$240 IS $240, not zero. I wasn't even aware of the option when I ordered the 31, as was the case with the Wi-Fi option. I have the entire winter to make up my mind. All that it does is allow you to set and select frequencies from the 9070 instead of the TY91, not a very compelling capability at the end of the day.
Tom
Updating Oudie [email protected] Soaring 0 July 14th 18 01:29 PM
XC Skies GFS not updating JS Soaring 4 June 2nd 16 10:34 PM
OLC Not Updating [email protected] Soaring 4 October 14th 10 11:04 PM
Updating B-100 Paul M. Cordell Soaring 2 November 12th 04 02:10 AM
