Gliding risk....
Old December 6th 19, 11:05 AM posted to rec.aviation.soaring
Terry Slater[_2_]
Default Gliding risk....
At 22:33 05 December 2019, 2G wrote:
On Thursday, December 5, 2019 at 11:15:08 AM UTC-8, Dave Walsh wrote:
At 16:14 05 December 2019, 2KA wrote:
Yeah, the entire fleet was inspected and repaired as required=20
(years ago),
and SH paid for the whole thing. Gliders built at the factory=20
in Germany
were found to be affected, as well as those built at=20
contractors.
Lynn Alley
"2KA"
=20
You were lucky! I was in a UK owned DuoDiscus based at=20
Sisteron, France, a few years ago. Wing spar de-bonding was=20
discovered at an annual inspection even though the glider had,=20
in theory, been inspected previously, looking for this specific=20
manufacturing fault. SH DECLINED TO PAY FOR THIS REPAIR;=20
if I recall correctly each of us in the 8 man syndicate had to=20
cough up about =C2=A3700.......
Dave Walsh
This is particularly disturbing, raising the question of the
effectiveness
of the original inspection method(s). Do the logbook(s) detail how and
when=
this inspection was done? How did the current annual discover the
de-bondi=
ng?
Tom
The inspections were performed with an endoscope, and the full length of
the spar bonding was inspected visually. SH issued a very comprehensive
guide to the process.
Terry
Old December 6th 19, 09:53 PM posted to rec.aviation.soaring
2G
(years ago),
in Germany
contractors.
Lynn Alley
"2KA"
=20
Dave Walsh
effectiveness
when=
de-bondi=
ng?
Tom
Terry
Yeah, I read their TN 396-08 that covered the process. This required cutting several holes in each wing for access by the endoscope. Of course, these holes had to be repaired and refinished. It would have been so much easier and cheaper to have done this inspection by ultrasonic NDT.
Tom
Old December 6th 19, 10:13 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
2G wrote on 12/6/2019 1:53 PM:
Tom
Terry
If the SH wing is constructed like the ASH26E wing, there is a layer of foam
between the outer skin and inner skin that is glued (hopefully) to spar. I suspect
ultrasound would not be effective, so what would kind of NDT would be used?
Old December 7th 19, 10:09 AM posted to rec.aviation.soaring
krasw
Reading this forum, sounds like biggest safety risks in gliding a
- Any glider or radio that has had an AD in it's history
- Rogue thermals
- Mysterious medical symptoms that occur only when flying
Other that that, we are pretty safe.
Old December 9th 19, 06:30 AM posted to rec.aviation.soaring
2G
- Rogue thermals
The biggest safety risks have been, and continue to be, pilot error.
Tom
Old December 10th 19, 12:10 AM posted to rec.aviation.soaring
Bob T
- Rogue thermals
Regarding the rogue thermal comment... they can occur. I came VERY close to becoming a statistic a few years ago while thermalling about 1500 ft. agl and wrote a feature article for SOARING MAGAZINE dealing with it. Rather than stalling an inside wing in a thermal turn (as one would expect if you happened to fly too slowly), while thermalling at about 10-15 kts above stall speed my INSIDE (lower) wing suddenly was pushed up and over, resulting in a steep dive / spiral. Subsequent research showed that some thermals can have strong down cores inside of overall lift, and if a glider happened to hit the sheer boundary, with suddenly one wing in the up air and the other in the down air, your day could quickly end.
See https://www.danlj.org/~danlj/Soaring...b_Thompson.pdf
and Dr. Dan Johnson had a good one, too https://www.danlj.org/~danlj/Soaring...Jan-p12-15.pdf
There are 2 books I referred to in my classes that have some pretty good info, too, although they are mostly intended for business folks:
1. Will Your Next Mistake Be Fatal? by Robert E. Mittelstaedt, Jr. for example - on page 160 - Insight #29 - Culture is powerful - what creates success may kill you. Think about this one seriously, for a long time! What you, or others, have gotten away with for a number of times can lead to complacency... and you becoming a statistic... that you couldn't tell anyone about ... from the grave. I recently attended a "celebration of life" for a friend that I suspect may have either lost his life due to his prior successes or rogue air.
2.Why We Make Mistakes by Joseph T. Hallinan
Old December 10th 19, 06:31 AM posted to rec.aviation.soaring
2G
- Rogue thermals
A thermal may not be your standard British thermal, but a confluence of several, competing mini-thermals. I have seen up to six, or more, dust devils converging to make a single thermal. However, in 40 years of flying, much in the very dynamic high western desert, I have never been upset in the manner you describe. This is not to say it can't happen, but I think the typical glider accident is much more mundane and the direct result of poor airmanship.
Tom
Old December 10th 19, 02:03 PM posted to rec.aviation.soaring
Tango Whisky
Le mardi 10 décembre 2019 07:31:14 UTC+1, 2G a écritÂ*:
- Rogue thermals
Tom
In 39 years of flying, I have once been upset by a thermal (entering at a speed of 130 kph, 300 m over the rocks in the central Alps, 4 m/s climb after recovery).
A second time such an upset was caused by a rotor (vertical speeds varying between -12 m/s and +12 m/s, trying to work it at 150 kph), but it didn't really come as a surprise.
Old December 10th 19, 05:00 PM posted to rec.aviation.soaring
Dan Marotta
I've been upset as described, but it was rotor, not a thermal.
There's no substitute for training...
- Rogue thermals
Tom
Dan, 5J
Old December 10th 19, 05:15 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Tom
We'll make sure that gets printed on your tombstone. Back when I was a young pilot and working toward my multi-engine instrument I read a story in NTSD briefs or reports or one of the bi-weekly pamphlets publications I was reading about fly/IFR, regarding a 7,000 hour ATP that stalled a Beech Baron on short final. I thought how could you be so dumb. That evening I was doing a night instrument training flight in a rent-a-wreck piper Semihole. This particular evening the buzzing in the headsets had been louder than normal. This was my first night flight after the airport installed a displaced threshold. While on long final, I thought I heard tower clear an aircraft to taxi onto the active runway and hold. I was gentling pulling myself up, by the yoke, to look over the cowling. The stall horn went off and to me it was lost in the background buzzzing noise in the electrical system. The instructor put his palm on the yoke and pushed it forward enough for the horn to stop. I was still concentrated on looking over cowling pull myself up by the yoke, the horn went off for a second time and the instructor said" I got it. " It was not until then I understood what I had been doing and what I had been ignoring. I never again thought I was beyond making a mistake! I try to stay very alert, I keep learning and I keep flying. Could I make an airmanship mistake, you bet I could. Because I know I can screw up, I keep up with training, flying, Condor, reading about flying, and staying fit to fly. When The above don't come together I am fast to ground myself. I think only a foolish pilot would think they can't make a mistake.
Stay safe out there,
Jon
YOUR safety is at risk BR549 Instrument Flight Rules 0 December 13th 07 12:21 AM
At risk of starting a religious war. Bruce Soaring 14 August 20th 07 08:41 AM
NGA US navigational data at risk? Doug Vetter Piloting 16 April 19th 07 01:46 AM
Safety at risk in FAA Peterpan Piloting 7 February 24th 05 08:58 PM
U.S. SCHOOLKIDS AT RISK Cribsheet Piloting 0 December 5th 04 05:29 PM
