Looking for pictures of motorglider failures
Old December 8th 19, 06:01 PM posted to rec.aviation.soaring
Default Looking for pictures of motorglider failures
Motor in a sailplane = a complicated abomination, ......
An efficient light power plane utilizing sailplane aerodynamics = beautiful engineering.,,,,
Old December 8th 19, 07:06 PM posted to rec.aviation.soaring
Jonathon May
At 18:47 08 December 2019, Eric Greenwell wrote:
Some where there is a photo of a propellor blade sticking out of a
duo discus wing.It was part of the AD sent out after a hub failure left
the blades coming off.
wrote on 12/8/2019 10:01 AM:
Look at an FES sailplane - simple. Much simpler than a towplane,
and much
easier
to schedule when you need a launch. I was part owner of a
towplane for
years, and
it caused me more grief each year than the self-launcher I now
own. And
then there
are the avoided retrieves - simple and priceless!
Are we really having this conversation after all these years, with
80% of
gliders going out the factory door with an engine?
email
me)
https://sites.google.com/site/motorg...ions/download-
the-guide-1
Old December 8th 19, 07:51 PM posted to rec.aviation.soaring
Duster[_2_]
\J. May:
I think this may be what you're referring to?
https://assets.publishing.service.go...SAXT_05-16.pdf
Old December 8th 19, 08:17 PM posted to rec.aviation.soaring
Jonathon May
At 19:51 08 December 2019, Duster wrote:
\J. May:
left
https://assets.publishing.service.go...14f22aed915d16
01000000/Schempp-Hirth_Duo_Discus_T_G-SAXT_05-16.pdf
Thats the incident butI have see more photos one was of a blade
impacted with a wing still I insintue
Old December 8th 19, 08:47 PM posted to rec.aviation.soaring
Dave Nadler
IIRC, more recent is the blade sticking out of a DG-1000 wing.
Different style hub (conventional 2-blade prop).
Anyone have that picture?
Old December 8th 19, 08:06 PM posted to rec.aviation.soaring
Dave Nadler
with 80% of the gliders going out the factory door with an engine?
That is PRECISELY why we're having this conversation.
Looking forward to your contributions,
Best Regards, Dave
PS: Old, but still relevant (I need to see if Jean Marie has an updated version):
http://www.streckenflug.at/download/motorprobleme.pdf
Old December 8th 19, 08:36 PM posted to rec.aviation.soaring
Jonathon May
engine?
Best Regards, Dave
updated
version):
Prop blade punctured fuselage, dented fuel tank and restricted
aileron movement. It nearly took out the brakes as well. The prop
had flown 38 hours
Missing blade
The flight manual says to check for cracks in the hub every day. This
is what a very badly cracked hub looks like.
There are photos I will try to put a link in.
Old December 8th 19, 09:38 PM posted to rec.aviation.soaring
Tom BravoMike
As the Italians put it: Donna e moto amore e dolore...
Old December 8th 19, 09:47 PM posted to rec.aviation.soaring
Duster[_2_]
Well, for one, my spouse has never failed me (and she's prettier than any Rotax, Solo or FES engine).
302 security failures T8 Soaring 17 April 8th 10 03:33 AM
MH EDS failures Philip Plane Soaring 6 December 16th 05 12:37 AM
Colibri failures? [email protected] Soaring 3 April 15th 05 12:30 AM
Colibri Failures. Stan Kochanowski Soaring 2 April 6th 05 01:00 PM
Colibri Failures. Stan Kochanowski Soaring 1 April 6th 05 12:24 PM
