Filling small holes in panel?
Old December 9th 19, 12:06 AM posted to rec.aviation.soaring
Default Filling small holes in panel?
On Sunday, December 8, 2019 at 4:00:40 PM UTC-5, Cookie wrote:
On Sunday, December 8, 2019 at 8:40:36 AM UTC-5, wrote:
On Saturday, December 7, 2019 at 6:12:08 PM UTC-5, soaringjac wrote:
Using the aluminum brazing method, the panel comes out flat on both sides...so new holes can be put where you need them. Patches on the backside and thru screws, and pockets of Bondo, may prove problematic if they interfere with the new installation.
Cookie
Any recommendations on what to use to fill small holes in an aluminum panel?
Very small(screw) holes can be filled by counter sinking and putting a flat head screw in, followed by a bit of filler.
Larger(switch size) holes, assuming no interference with something on the back face, can be covered from the back by a small piece of aluminum, bonded with epoxy, followed by filling he hole with body filler.
Unsupported body filler will fail in a short time.
Good Luck
UH
How to determine if your ASG29 has the large or small panel? Sean Fidler Soaring 37 November 19th 14 06:50 PM
Trying to fill some holes in the instrument panel [email protected] Soaring 2 February 12th 14 02:55 AM
Cutting 57mm holes in the instrument panel.....how to? John Bojack[_2_] Soaring 20 November 12th 10 09:15 PM
When Poorboys drill holes ...was: Drilling holes in steel tubing wright1902glider Home Built 4 November 4th 05 01:19 AM
Filling Holes AKperson Owning 1 July 20th 05 03:54 PM
