Looking for pictures of motorglider failures
Old December 10th 19, 06:48 AM posted to rec.aviation.soaring
2G
Default Looking for pictures of motorglider failures
On Monday, December 9, 2019 at 2:45:07 PM UTC-8, BG wrote:
On Saturday, December 7, 2019 at 9:27:51 AM UTC-8, Dave Nadler wrote:
I've been persuaded to give an OSTIV talk about motorglider safety issues,
in particular propulsion system failures. I'm going to discuss
common failures, the systemic reasons this stuff has happened and
WILL CONTINUE to happen, and some ideas for systemic improvements.
I'm looking for pictures and/or documentation of failures, for example:
- failed position switches (ie limit switches, prop position sensor)
- failed fuel systems (improper hoses, routing, leak sources, etc)
- failed structural components (cracked exhaust, mounts, pylons, etc)
- failed drive belts
- failed electrical connectors
- failed motor controller
- failed electronics
and anything else you might happen to have.
Ideally a good photo, make and model, approximate date, brief description.
Please email to me offline.
Thanks in advance for the help!
Best Regards, Dave
PS: Probably time to redo this study, but situation isn't that much changed:
http://www.nadler.com/public/DeRese_...ilplanes.p df
In the late 80's a DG 400 taking off from El Tiro lost his prop after the bolts sheared off. It was concluded the wooden prop had shrunk and the bolts were free to move. It happened about 1000AGL, those of us who were watching heard the engine rev really high then a shut down followed by call on the radio for a emergency landing. The prop walked down the wing hitting it three times, the last hit near the end went through the top and bottoms skins. All was OK on landing.
DR Jack's ASW 26e had a fire in the engine bay that nearly burnt the tall boom off. A belt came apart and cut a fuel line. He stayed with the plane till landing. As I was in the shop, the repair people were amazed it did not break off, the composited was completely burned through in most places..
My worse events in my DG 800b were a failure of the uphaul motor so I could not retract the engine and second was a contamination in the fuel line after they were replaced. Debris kept the needle valve open so the engine was flooding on a air restart. Using full throttle it would run, preventing a landout
BG
Dr Jack's in-flight fire was the scariest incident I have heard of. Does anyone know if he shut off fuel after the start of the fire?
Tom
Old December 11th 19, 04:37 PM posted to rec.aviation.soaring
Frank Whiteley
Best Regards, Dave
BG
Tom
Haven't there been 3-4 Stemme in-flight fires world wide?
Frank
Old December 11th 19, 05:02 PM posted to rec.aviation.soaring
Dan Marotta
....And this is why I already have a fire plan for my Stemme: ENGINE FIRE
https://www.dropbox.com/s/gu2yzjylio6wajg/PastedGraphic-1.tiff?dl=0
Best Regards, Dave
BG
Tom
Frank
Dan, 5J
Old December 11th 19, 05:24 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Dan Marotta wrote on 12/11/2019 9:02 AM:
What is the plan?
Old December 11th 19, 05:27 PM posted to rec.aviation.soaring
JS[_5_]
After Rex Mayes and I came up with a nice fire extinguisher system for ASH26E a decade ago, denial of the need for such a system seemed quite popular.
How many similar systems have been installed by owners?
How many manufaturers offer options like this?
Sorry, don't have a photo of the two emitters in the engine compartment.
https://www.dropbox.com/sh/nidqq8s4s...KIQg2dCta?dl=0
Old December 11th 19, 08:16 PM posted to rec.aviation.soaring
Dan Marotta
Several of the Stemme owners are looking at this product:
https://proteng.com/pictures/
Dan, 5J
Old December 11th 19, 10:38 PM posted to rec.aviation.soaring
Dave Nadler
That looks like a good solution for a closed space, but will it have a meaningful effect in an area with air forced through at high volume? Would you have a separate warning so you'd know to close the Stemme vents? Probably wouldn't work in an MG with an open engine bay (doors that don't close)?
Old December 11th 19, 07:10 PM posted to rec.aviation.soaring
Dan Daly[_2_]
What is the plan?
1. Evacuate
2. Run upwind
3. Take photos
Old December 11th 19, 11:13 PM posted to rec.aviation.soaring
Jonathan St. Cloud
What is the plan?
1. Evacuate
2. Run upwind
3. Take photos
Dan you need to get with the times. 1) Take selfie; 2) Evacuate; 3) Take selfie; 4) Run upwind while taking self video; 5) take videos, selfies, post to social media...then check for survivors, contact appropriate arthurites.
Old December 12th 19, 12:33 AM posted to rec.aviation.soaring
Dan Marotta
Social media?Â* What's that?
What is the plan?
1. Evacuate
2. Run upwind
3. Take photos
Dan, 5J
302 security failures T8 Soaring 17 April 8th 10 03:33 AM
MH EDS failures Philip Plane Soaring 6 December 16th 05 12:37 AM
Colibri failures? [email protected] Soaring 3 April 15th 05 12:30 AM
Colibri Failures. Stan Kochanowski Soaring 2 April 6th 05 01:00 PM
Colibri Failures. Stan Kochanowski Soaring 1 April 6th 05 12:24 PM
