On Monday, December 9, 2019 at 11:48:33 PM UTC-7, 2G wrote:
On Monday, December 9, 2019 at 2:45:07 PM UTC-8, BG wrote: On Saturday, December 7, 2019 at 9:27:51 AM UTC-8, Dave Nadler wrote: I've been persuaded to give an OSTIV talk about motorglider safety issues, in particular propulsion system failures. I'm going to discuss common failures, the systemic reasons this stuff has happened and WILL CONTINUE to happen, and some ideas for systemic improvements. I'm looking for pictures and/or documentation of failures, for example: - failed position switches (ie limit switches, prop position sensor) - failed fuel systems (improper hoses, routing, leak sources, etc) - failed structural components (cracked exhaust, mounts, pylons, etc) - failed drive belts - failed electrical connectors - failed motor controller - failed electronics and anything else you might happen to have. Ideally a good photo, make and model, approximate date, brief description. Please email to me offline. Thanks in advance for the help! Best Regards, Dave PS: Probably time to redo this study, but situation isn't that much changed: http://www.nadler.com/public/DeRese_...ilplanes.p df In the late 80's a DG 400 taking off from El Tiro lost his prop after the bolts sheared off. It was concluded the wooden prop had shrunk and the bolts were free to move. It happened about 1000AGL, those of us who were watching heard the engine rev really high then a shut down followed by call on the radio for a emergency landing. The prop walked down the wing hitting it three times, the last hit near the end went through the top and bottoms skins. All was OK on landing. DR Jack's ASW 26e had a fire in the engine bay that nearly burnt the tall boom off. A belt came apart and cut a fuel line. He stayed with the plane till landing. As I was in the shop, the repair people were amazed it did not break off, the composited was completely burned through in most places. My worse events in my DG 800b were a failure of the uphaul motor so I could not retract the engine and second was a contamination in the fuel line after they were replaced. Debris kept the needle valve open so the engine was flooding on a air restart. Using full throttle it would run, preventing a landout BG Dr Jack's in-flight fire was the scariest incident I have heard of. Does anyone know if he shut off fuel after the start of the fire? Tom Haven't there been 3-4 Stemme in-flight fires world wide? Frank |
....And this is why I already have a fire plan for my Stemme: ENGINE FIRE
https://www.dropbox.com/s/gu2yzjylio6wajg/PastedGraphic-1.tiff?dl=0 On 12/11/2019 9:37 AM, Frank Whiteley wrote: On Monday, December 9, 2019 at 11:48:33 PM UTC-7, 2G wrote: On Monday, December 9, 2019 at 2:45:07 PM UTC-8, BG wrote: On Saturday, December 7, 2019 at 9:27:51 AM UTC-8, Dave Nadler wrote: I've been persuaded to give an OSTIV talk about motorglider safety issues, in particular propulsion system failures. I'm going to discuss common failures, the systemic reasons this stuff has happened and WILL CONTINUE to happen, and some ideas for systemic improvements. I'm looking for pictures and/or documentation of failures, for example: - failed position switches (ie limit switches, prop position sensor) - failed fuel systems (improper hoses, routing, leak sources, etc) - failed structural components (cracked exhaust, mounts, pylons, etc) - failed drive belts - failed electrical connectors - failed motor controller - failed electronics and anything else you might happen to have. Ideally a good photo, make and model, approximate date, brief description. Please email to me offline. Thanks in advance for the help! Best Regards, Dave PS: Probably time to redo this study, but situation isn't that much changed: http://www.nadler.com/public/DeRese_...ilplanes.p df In the late 80's a DG 400 taking off from El Tiro lost his prop after the bolts sheared off. It was concluded the wooden prop had shrunk and the bolts were free to move. It happened about 1000AGL, those of us who were watching heard the engine rev really high then a shut down followed by call on the radio for a emergency landing. The prop walked down the wing hitting it three times, the last hit near the end went through the top and bottoms skins. All was OK on landing. DR Jack's ASW 26e had a fire in the engine bay that nearly burnt the tall boom off. A belt came apart and cut a fuel line. He stayed with the plane till landing. As I was in the shop, the repair people were amazed it did not break off, the composited was completely burned through in most places. My worse events in my DG 800b were a failure of the uphaul motor so I could not retract the engine and second was a contamination in the fuel line after they were replaced. Debris kept the needle valve open so the engine was flooding on a air restart. Using full throttle it would run, preventing a landout BG Dr Jack's in-flight fire was the scariest incident I have heard of. Does anyone know if he shut off fuel after the start of the fire? Tom Haven't there been 3-4 Stemme in-flight fires world wide? Frank -- Dan, 5J |
Dan Marotta wrote on 12/11/2019 9:02 AM:
...And this is why I already have a fire plan for my Stemme: ENGINE FIRE https://www.dropbox.com/s/gu2yzjylio6wajg/PastedGraphic-1.tiff?dl=0 What is the plan? -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 |
After Rex Mayes and I came up with a nice fire extinguisher system for ASH26E a decade ago, denial of the need for such a system seemed quite popular.
How many similar systems have been installed by owners? How many manufaturers offer options like this? Sorry, don't have a photo of the two emitters in the engine compartment. Jim https://www.dropbox.com/sh/nidqq8s4s...KIQg2dCta?dl=0 |
Several of the Stemme owners are looking at this product:
https://proteng.com/pictures/ On 12/11/2019 10:27 AM, JS wrote: After Rex Mayes and I came up with a nice fire extinguisher system for ASH26E a decade ago, denial of the need for such a system seemed quite popular. How many similar systems have been installed by owners? How many manufaturers offer options like this? Sorry, don't have a photo of the two emitters in the engine compartment. Jim https://www.dropbox.com/sh/nidqq8s4s...KIQg2dCta?dl=0 -- Dan, 5J |
On Wednesday, December 11, 2019 at 3:16:32 PM UTC-5, Dan Marotta wrote:
Several of the Stemme owners are looking at this product: https://proteng.com/pictures/ That looks like a good solution for a closed space, but will it have a meaningful effect in an area with air forced through at high volume? Would you have a separate warning so you'd know to close the Stemme vents? Probably wouldn't work in an MG with an open engine bay (doors that don't close)? |
Tests have shown that the air flow through the cowling of an airplane is
much slower than the dispersion velocity of this product.Â* I don't have data for the Stemme, but I'd imagine it's similar. You can't close the vents in a Stemme while the engine is running without incurring a bill in excess of $35-40 thousand dollars. The Stemme has a fire warning system which alarms before these tubes release their suppressant thereby allowing the pilot to close the fuel valve and shut down the engine. The cost of this system is less than that of an iPhone. I doubt this system would work in a glider with an open engine bay. On 12/11/2019 3:38 PM, Dave Nadler wrote: On Wednesday, December 11, 2019 at 3:16:32 PM UTC-5, Dan Marotta wrote: Several of the Stemme owners are looking at this product: https://proteng.com/pictures/ That looks like a good solution for a closed space, but will it have a meaningful effect in an area with air forced through at high volume? Would you have a separate warning so you'd know to close the Stemme vents? Probably wouldn't work in an MG with an open engine bay (doors that don't close)? -- Dan, 5J |
On Wednesday, December 11, 2019 at 12:24:13 PM UTC-5, Eric Greenwell wrote:
Dan Marotta wrote on 12/11/2019 9:02 AM: ...And this is why I already have a fire plan for my Stemme: ENGINE FIRE https://www.dropbox.com/s/gu2yzjylio6wajg/PastedGraphic-1.tiff?dl=0 What is the plan? -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 1. Evacuate 2. Run upwind 3. Take photos |
On Wednesday, December 11, 2019 at 11:11:01 AM UTC-8, Dan Daly wrote:
On Wednesday, December 11, 2019 at 12:24:13 PM UTC-5, Eric Greenwell wrote: Dan Marotta wrote on 12/11/2019 9:02 AM: ...And this is why I already have a fire plan for my Stemme: ENGINE FIRE https://www.dropbox.com/s/gu2yzjylio6wajg/PastedGraphic-1.tiff?dl=0 What is the plan? -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 1. Evacuate 2. Run upwind 3. Take photos Dan you need to get with the times. 1) Take selfie; 2) Evacuate; 3) Take selfie; 4) Run upwind while taking self video; 5) take videos, selfies, post to social media...then check for survivors, contact appropriate arthurites. |
Social media?Â* What's that?
On 12/11/2019 4:13 PM, Jonathan St. Cloud wrote: On Wednesday, December 11, 2019 at 11:11:01 AM UTC-8, Dan Daly wrote: On Wednesday, December 11, 2019 at 12:24:13 PM UTC-5, Eric Greenwell wrote: Dan Marotta wrote on 12/11/2019 9:02 AM: ...And this is why I already have a fire plan for my Stemme: ENGINE FIRE https://www.dropbox.com/s/gu2yzjylio6wajg/PastedGraphic-1.tiff?dl=0 What is the plan? -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 1. Evacuate 2. Run upwind 3. Take photos Dan you need to get with the times. 1) Take selfie; 2) Evacuate; 3) Take selfie; 4) Run upwind while taking self video; 5) take videos, selfies, post to social media...then check for survivors, contact appropriate arthurites. -- Dan, 5J |
302 security failures | T8 | Soaring | 17 | April 8th 10 03:33 AM |
MH EDS failures | Philip Plane | Soaring | 6 | December 16th 05 12:37 AM |
Colibri failures? | [email protected] | Soaring | 3 | April 15th 05 12:30 AM |
Colibri Failures. | Stan Kochanowski | Soaring | 2 | April 6th 05 01:00 PM |
Colibri Failures. | Stan Kochanowski | Soaring | 1 | April 6th 05 12:24 PM |
