1981 Cobra trailer gas struts
Old June 19th 20, 03:46 PM posted to rec.aviation.soaring
Default 1981 Cobra trailer gas struts
Nice work. I had to do that for an older (1978) Komet many years ago and, like you, was shocked at just how heavy the top is.
Two thoughts:
1. It should be obvious but rod-end-down/body-end-up can be different in the raised and lowered positions. I've seen trailers that way and the LS-3 landing gear is also, forcing you to pick one alternative. I go for the position that the mechanism is in 99% of the time (i.e., top down for a trailer)..
2. The attach bolts are cantilevered out beyond the trailer wall and have been known to fail. I suspect that's more likely if you insert a lot of washers as spacers. Just be careful to monitor that. They apparently bend before they fail so you should see it. I don't know what was there originally but consider sourcing some Grade 8 or other very-high-strength bolts. Maybe even drilling out the holes oversize and going up in size.
Perhaps someone else can comment on bolt failures. It's a known, apparently not-very-common, but potentially disastrous weakness.
It's a greatÂ*feeling to get everything installed and working--even though all you have is what you started out with.
Chip Bearden
JB
Old June 20th 20, 02:22 AM posted to rec.aviation.soaring
Frank Whiteley
Two thoughts:
Chip Bearden
JB
I seem to recall that the Komet trailers originally came with 8mm bolts and that because of the failures it was recommended to replace them with 10mm bolts.
Frank Whiteley
Old June 20th 20, 12:59 PM posted to rec.aviation.soaring
David Cleveland
Referencing Chips comment about using harder bots. He is absolutely correct.. Many trailers I've seen, mine included, have multiple washers at the mounting point to move the strut and spring arms out away from the trailer. Use caution.
Metric bolts have a different hardness grading system. A metric bolt marked 8.8 is the same hardness as an SAE grade 5. If you want to upgrade the hardness of a metric bolt, use a 10.9 or even 12.9. Frank's comment about using a large diameter bolt would be a good idea as well.
Old June 20th 20, 05:02 PM posted to rec.aviation.soaring
Richard Pfiffner[_2_]
On Saturday, June 20, 2020 at 4:59:06 AM UTC-7, David Cleveland wrote:
Referencing Chips comment about using harder bots. He is absolutely correct. Many trailers I've seen, mine included, have multiple washers at the mounting point to move the strut and spring arms out away from the trailer. Use caution.
If you can't find metric you could use 5/16" grade 8 bolts these are only .0015" smaller than an 8mm basically the same.
McMaster Carr has a selection of grade 8 both the carriage bolt that is used on the bottom end and the hex head used on the upper. Also use the nyloc nuts. Highest grade they offer on the carriage is 8, 10 offered for the upper bolts.
They have the both metric bolts in the 8.8 or Grade 5.
Richard
www.craggyaero.com
Cobra Gas Struts Karl Striedieck[_2_] Soaring 38 September 14th 16 12:48 AM
Cobra trailer struts [email protected] Soaring 4 September 9th 14 02:36 AM
For sale a pair of Cobra Lift struts 1100 N Mike Hostage Soaring 0 July 23rd 13 05:43 PM
Trailer tires for old (1981) Komet Trailer [email protected] Soaring 3 May 13th 09 10:24 PM
Cobra trailer lift struts for clamshell top [email protected] Soaring 4 March 4th 08 11:55 AM
