Filling small holes in panel?
Old December 16th 19, 01:59 AM posted to rec.aviation.soaring
Scott Williams[_2_]
Default Filling small holes in panel?
On Saturday, December 7, 2019 at 5:12:08 PM UTC-6, soaringjac wrote:
Any recommendations on what to use to fill small holes in an aluminum panel?
My preferred method is to make a new panel. at least as long as the original was flat plate aluminum. The classic gliders I can afford (SHK, Std Cirrus, Phoebus, Grob 103) all have had aluminum plate panels, usually pretty ragged from multiple instrument changes over the years and making a new one only takes 3 or 4 hours and I can put the instruments where I want.
Of course a band saw and drill press make this possible in my case.
Good Luck,
Scott
How to determine if your ASG29 has the large or small panel? Sean Fidler Soaring 37 November 19th 14 06:50 PM
Trying to fill some holes in the instrument panel [email protected] Soaring 2 February 12th 14 02:55 AM
Cutting 57mm holes in the instrument panel.....how to? John Bojack[_2_] Soaring 20 November 12th 10 09:15 PM
When Poorboys drill holes ...was: Drilling holes in steel tubing wright1902glider Home Built 4 November 4th 05 01:19 AM
Filling Holes AKperson Owning 1 July 20th 05 03:54 PM
