On Tuesday, December 17, 2019 at 2:01:56 PM UTC-5, Eric Greenwell wrote:
Boise Pilot wrote on 12/17/2019 10:19 AM: On Tuesday, December 17, 2019 at 10:15:29 AM UTC-7, Jonathan St. Cloud wrote: On Tuesday, December 17, 2019 at 8:06:29 AM UTC-8, Matt Herron Jr. wrote: On Monday, December 16, 2019 at 4:43:23 PM UTC-8, JS wrote: Good shocks seemed to have the biggest effect in my experience. I have used three different model year Jeep Grand Cherokees as tow cars for over 35 years. Nelson Funston (JN) is a tire and trailer expert with big heavy trailers. With my first Jeep, told me to do three things in following order: -Move some weight forward,-stiffer sidewall trailer tires at max pressure, -vehicle tires at max pressure. Ancillary advice, maintain Jeep shocks... We have some interstate speeds of 80 mph in Idaho. No sway!! All my Jeeps were the 8cyl model so heavier than the old 4cyl and most currently available 6cly on the road. Also all had 4 wheel drive and the off road accessory that has different suspension and road clearance. Boise Pilot Look out when moving trailer weight forward... Never exceed the maximum tongue weight! Jim Also tighten up the hitch in the receiver with one of these: they take out the slop that can add to sway, and quiet down the rig I found once I stopped towing with a Jeep Grand Cherokee I had no more sway problems. Anyone that wants to hear more from Nelson Funston can download his OSTIV paper on trailer stability he http://journals.sfu.ca/ts/index.php/...wnload/779/737 -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...load-the-guide Interesting paper, thanks for the link. But I'm puzzled by Funston's remark at bottom of p34 that "Bias ply tires generally have 25 % io 30% lower lateral stiffness than radials and are not recommended for use on glider trailers". Almost every other article I've seen on the web about trailer tires recommends the opposite: i.e. bias ply trailer tires (marked "D" on the sidewall) have stiffer sidewalls and cut down trailer sway. What are others' opinions on bias vs radial trailer tires? Ian "IN" |
India November wrote on 12/20/2019 7:53 PM:
On Tuesday, December 17, 2019 at 2:01:56 PM UTC-5, Eric Greenwell wrote: Anyone that wants to hear more from Nelson Funston can download his OSTIV paper on trailer stability he http://journals.sfu.ca/ts/index.php/...wnload/779/737 -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...load-the-guide Interesting paper, thanks for the link. But I'm puzzled by Funston's remark at bottom of p34 that "Bias ply tires generally have 25 % io 30% lower lateral stiffness than radials and are not recommended for use on glider trailers". Almost every other article I've seen on the web about trailer tires recommends the opposite: i.e. bias ply trailer tires (marked "D" on the sidewall) have stiffer sidewalls and cut down trailer sway. What are others' opinions on bias vs radial trailer tires? These claims are made by people that do not realize it is the tread stiffness (resistance to lateral deflection) is the important factor in a tire's behavior. The stiffer the tread, the smaller the slip angle, and small slip angles improve vehicle stability. https://suspensionsecrets.co.uk/tyre-slip-angle/ This is not opinion, but engineering fact. Instead of seeking opinions, I suggest you look for facts; for example, look at tire company websites, tire recommendations for things like travel trailers, or even wander about a RV trailer lot, and note the radial tires on all the trailers. The only good feature of a bias ply trailer tire is the lower price. As a side note, bias ply trailer tires don't necessarily have the "stiffest" sidewall (as measured by the "push" method). A few years ago, I measured that stiffness on three similar sized tires, with the same load rating, for a glider trailer. The stiffest was an LT (light truck tire), 2nd stiffest was the ST radial tire, and least stiff was the ST bias ply tire. The LT tire was the most stable, the ST bias ply tire was the least stable. I can send you a copy of the test results if you want it. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 |
Note that Nelson Funston's Trailer Dynamics paper was written in 1987. I would bet that tire technology has changed somewhat in the intervening 32 years. Still, the paper is interesting and informative.
On Saturday, December 21, 2019 at 7:56:08 AM UTC-8, Eric Greenwell wrote:
wrote on 12/21/2019 6:39 AM: Note that Nelson Funston's Trailer Dynamics paper was written in 1987. I would bet that tire technology has changed somewhat in the intervening 32 years. Still, the paper is interesting and informative. The steel belted radial was well-established in 1987. I've discussed tires, particularly trailer tires, with Nelson many times since then, including recently about the specific tires to get for my trailer. He has never mentioned any changes to tire technology that would affect us, nor have I heard of anything. Also, there is nothing in his paper that depends directly on tire technology. It's the lateral stiffness of the tire tread that is important; then and now, radial tires have significantly more stiffness that a comparable bias ply tire. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 Light truck tires are not available in a size that fits Cobra trailers. Found that out this last summer when I had to replace a blown tire. Tom |
On Saturday, December 21, 2019 at 5:51:26 PM UTC-8, 2G wrote:
On Saturday, December 21, 2019 at 7:56:08 AM UTC-8, Eric Greenwell wrote: wrote on 12/21/2019 6:39 AM: Note that Nelson Funston's Trailer Dynamics paper was written in 1987.. I would bet that tire technology has changed somewhat in the intervening 32 years. Still, the paper is interesting and informative. The steel belted radial was well-established in 1987. I've discussed tires, particularly trailer tires, with Nelson many times since then, including recently about the specific tires to get for my trailer. He has never mentioned any changes to tire technology that would affect us, nor have I heard of anything. Also, there is nothing in his paper that depends directly on tire technology. It's the lateral stiffness of the tire tread that is important; then and now, radial tires have significantly more stiffness that a comparable bias ply tire.. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 Light truck tires are not available in a size that fits Cobra trailers. Found that out this last summer when I had to replace a blown tire. Tom The curious thing in the LT vs ST debate is WHY would a tire company design a BETTER trailer tire intended to be put on a truck than a tire SPECIFICALLY and EXCLUSIVELY to be used on trailers? Just doesn't make any sense. Note that is a different question as to is it ok to use an LT tire on a trailer. |
2G wrote on 12/21/2019 6:23 PM:
On Saturday, December 21, 2019 at 5:51:26 PM UTC-8, 2G wrote: Light truck tires are not available in a size that fits Cobra trailers. Found that out this last summer when I had to replace a blown tire. Tom The curious thing in the LT vs ST debate is WHY would a tire company design a BETTER trailer tire intended to be put on a truck than a tire SPECIFICALLY and EXCLUSIVELY to be used on trailers? Just doesn't make any sense. Note that is a different question as to is it ok to use an LT tire on a trailer. LT tires make fine trailer tires; after all, they can handle the more demanding life on a truck. But! They cost more - often much more - than a trailer tire, due in part to the much higher speed rating, and that's why the tire companies make trailer tires. Who would buy a $124 LT tire when they can get an ST tire for $80? -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 |
2G wrote on 12/21/2019 5:51 PM:
On Saturday, December 21, 2019 at 7:56:08 AM UTC-8, Eric Greenwell wrote: wrote on 12/21/2019 6:39 AM: Note that Nelson Funston's Trailer Dynamics paper was written in 1987. I would bet that tire technology has changed somewhat in the intervening 32 years. Still, the paper is interesting and informative. The steel belted radial was well-established in 1987. I've discussed tires, particularly trailer tires, with Nelson many times since then, including recently about the specific tires to get for my trailer. He has never mentioned any changes to tire technology that would affect us, nor have I heard of anything. Also, there is nothing in his paper that depends directly on tire technology. It's the lateral stiffness of the tire tread that is important; then and now, radial tires have significantly more stiffness that a comparable bias ply tire. Light truck tires are not available in a size that fits Cobra trailers. Found that out this last summer when I had to replace a blown tire. Yokohama Supervan Y356 LT195/75R14 fit my ASH 26 E trailer. I got them from Tirerack.com, and they still carry them. Walmart has them, too, but you might have to order them first if you want to pick them up locally. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 |
On Friday, December 20, 2019 at 11:56:12 PM UTC-5, Eric Greenwell wrote:
India November wrote on 12/20/2019 7:53 PM: On Tuesday, December 17, 2019 at 2:01:56 PM UTC-5, Eric Greenwell wrote: Anyone that wants to hear more from Nelson Funston can download his OSTIV paper on trailer stability he http://journals.sfu.ca/ts/index.php/...wnload/779/737 -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...load-the-guide Interesting paper, thanks for the link. But I'm puzzled by Funston's remark at bottom of p34 that "Bias ply tires generally have 25 % io 30% lower lateral stiffness than radials and are not recommended for use on glider trailers". Almost every other article I've seen on the web about trailer tires recommends the opposite: i.e. bias ply trailer tires (marked "D" on the sidewall) have stiffer sidewalls and cut down trailer sway. What are others' opinions on bias vs radial trailer tires? These claims are made by people that do not realize it is the tread stiffness (resistance to lateral deflection) is the important factor in a tire's behavior. The stiffer the tread, the smaller the slip angle, and small slip angles improve vehicle stability. https://suspensionsecrets.co.uk/tyre-slip-angle/ This is not opinion, but engineering fact. Instead of seeking opinions, I suggest you look for facts; for example, look at tire company websites, tire recommendations for things like travel trailers, or even wander about a RV trailer lot, and note the radial tires on all the trailers. The only good feature of a bias ply trailer tire is the lower price. As a side note, bias ply trailer tires don't necessarily have the "stiffest" sidewall (as measured by the "push" method). A few years ago, I measured that stiffness on three similar sized tires, with the same load rating, for a glider trailer. The stiffest was an LT (light truck tire), 2nd stiffest was the ST radial tire, and least stiff was the ST bias ply tire. The LT tire was the most stable, the ST bias ply tire was the least stable. I can send you a copy of the test results if you want it. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 Hi Eric, Thanks for your reply. I hear you and accept what you say. Many sources out there on the www (wild, wild web) with advice on trailer towing say that bias-ply tires have stiffer sidewalls and reduce trailer sway--just one example being https://www.westmarine.com/WestAdvis...er-Tire-Basics. Not arguing, just sayin'. I am be interested in reading your test results. Please email at iandotgrant12atgmaildotcom Many thanks! IN |
India November wrote on 12/20/2019 7:53 PM: On Tuesday, December 17, 2019 at 2:01:56 PM UTC-5, Eric Greenwell wrote: Anyone that wants to hear more from Nelson Funston can download his OSTIV paper on trailer stability he http://journals.sfu.ca/ts/index.php/...wnload/779/737 -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...load-the-guide Interesting paper, thanks for the link. But I'm puzzled by Funston's remark at bottom of p34 that "Bias ply tires generally have 25 % io 30% lower lateral stiffness than radials and are not recommended for use on glider trailers". Almost every other article I've seen on the web about trailer tires recommends the opposite: i.e. bias ply trailer tires (marked "D" on the sidewall) have stiffer sidewalls and cut down trailer sway. What are others' opinions on bias vs radial trailer tires? These claims are made by people that do not realize it is the tread stiffness (resistance to lateral deflection) is the important factor in a tire's behavior. The stiffer the tread, the smaller the slip angle, and small slip angles improve vehicle stability. https://suspensionsecrets.co.uk/tyre-slip-angle/ This is not opinion, but engineering fact. Instead of seeking opinions, I suggest you look for facts; for example, look at tire company websites, tire recommendations for things like travel trailers, or even wander about a RV trailer lot, and note the radial tires on all the trailers. The only good feature of a bias ply trailer tire is the lower price. As a side note, bias ply trailer tires don't necessarily have the "stiffest" sidewall (as measured by the "push" method). A few years ago, I measured that stiffness on three similar sized tires, with the same load rating, for a glider trailer. The stiffest was an LT (light truck tire), 2nd stiffest was the ST radial tire, and least stiff was the ST bias ply tire. The LT tire was the most stable, the ST bias ply tire was the least stable. I can send you a copy of the test results if you want it. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 Hi Eric, Thanks for your reply. I hear you and accept what you say. Many sources out there on the www (wild, wild web) with advice on trailer towing say that bias-ply tires have stiffer sidewalls and reduce trailer sway--just one example being https://www.westmarine.com/WestAdvis...er-Tire-Basics. Not arguing, just sayin'. I am interested in reading your test results. Please email me at iandotgrant12atgmaildotcom Many thanks! IN |
Do trailers with coil springs and shock absorbers sway at higher speeds? | son_of_flubber | Soaring | 35 | July 8th 14 10:30 PM |
Dual axle sway | glider[_2_] | Soaring | 7 | March 2nd 10 04:36 AM |
US - 2009 explorer - trailer sway control | Gary Emerson | Soaring | 1 | October 15th 08 06:27 AM |
Attention SkyLune: FAA To Fund Noise-mitigation Measures | Larry Dighera | Piloting | 1 | July 8th 06 05:36 PM |
trailer sway | [email protected] | Soaring | 14 | June 19th 05 09:02 AM |
