Locating Transponder Antenna on top of the fuselage instead of under it.
Old December 29th 19, 02:43 AM posted to rec.aviation.soaring
Darryl Ramm
Default Locating Transponder Antenna on top of the fuselage instead ofunder it.
On Saturday, December 28, 2019 at 4:10:30 PM UTC-8, wrote:
"Pay attention to the proper ground plane installation with any of the standard external transponder 1/4 wave antenna. That is very important."
Can the ground Plane be inside a carbon fibre fuselage for an external blade type antenna ?
Dan
The ground plane you install would normally be inside the CF fuselage. And the antenna manufacture or glider manufacturer should provide instructions on how to do this properly. A part of the point of that aluminium plate or foil tape ground plane is to help with a good connection to the coax cable ground. In some cases you might scuff the inside of the fueslage to help make additional electrical connection to the carbon fibre weave. *Follow the directions your glider manufacturer provides.* A plate especially can also help provide a good solid surface for antenna lock washers to engage with. Clearly here the CF will act in part as a ground plane (even without a good direct electrical connection, but by backing it with a better conductor with good connection to the coax you are helping things along).
Old December 29th 19, 05:23 AM posted to rec.aviation.soaring
Well here is a link to a picture of a Ventus with the transponder antenna located as per Schempp Hirth.
Seems to work well only is straight flight. In any banking flight, the antenna is shadowed by the fuselage and/or wings.
Maybe a location on the turtledeck is better ?
https://www.airliners.net/photo/-/Sc...HgcaJ1/QJ2lC9A
Dan
Old December 29th 19, 06:27 AM posted to rec.aviation.soaring
Darryl Ramm
Dan
Thanks for the photo, ouch yep that looks like a dopey position, if above is the only other practical option I'd do that.
Old December 30th 19, 05:36 AM posted to rec.aviation.soaring
GliderCZ
Dan
I've got a Ventus 2c with a flexible antenna positioned exactly like that, per SH recommendations, and have passed a dozen ADS-B checks in the last year, with lots of low altitude yanking and banking.
Old December 30th 19, 05:47 AM posted to rec.aviation.soaring
Do you have the Blade type antenna or the cylinder/ball one ?
Thanks, Dan
Old December 30th 19, 06:06 AM posted to rec.aviation.soaring
GliderCZ
Thanks, Dan
Flexible, similar to the one linked (not HpH branded, as far as I know).
https://wingsandwheels.com/hph-trans...r-antenna.html
Old December 29th 19, 04:02 PM posted to rec.aviation.soaring
Dan Marotta
I think while Darryl's suggestion will work quite well, it is more
effort than is required.Â* The BNC connector and the nut and washer of a
rod antenna will provide the necessary electrical connection to the
ground plane.Â* With a blade antenna, the mounting studs will make a good
mechanical connection.
In my former LAK-17a, I used an aluminum square cut to the dimensions
specified in the antenna installation sheet and rolled it over an oxygen
tank to match the internal curvature of the fuselage aft of the landing
gear.Â* I glued it in place with contact cement knowing that the studs
and BNC would make a good mechanical and electrical connection.Â* It
worked great!Â* I mounted the antenna offset to one side for two
reasons;Â* first, the joint line of the fuselage halves was thicker than
the length of the studs and BNC, and second, it insured that the blade
antenna would not catch on the ramp when loading and unloading the
fuselage in the trailer.
Dan
Dan, 5J
Old December 30th 19, 02:48 AM posted to rec.aviation.soaring
2G
Dan
The ground plane you install would normally be inside the CF fuselage. And the antenna manufacture or glider manufacturer should provide instructions on how to do this properly. A part of the point of that aluminium plate or foil tape ground plane is to help with a good connection to the coax cable ground. In some cases you might scuff the inside of the fueslage to help make additional electrical connection to the carbon fibre weave. *Follow the directions your glider manufacturer provides.* A plate especially can also help provide a good solid surface for antenna lock washers to engage with.. Clearly here the CF will act in part as a ground plane (even without a good direct electrical connection, but by backing it with a better conductor with good connection to the coax you are helping things along).
Not all transponder antennas need a ground plane:
https://wingsandwheels.com/avionics-...as/l2-aae.html
Old December 30th 19, 02:58 AM posted to rec.aviation.soaring
Darryl Ramm
Dan
You are replying to a thread that clearly stated "with any of the standard external transponder 1/4 wave antenna." Are you adding value here?
Old December 30th 19, 03:32 AM posted to rec.aviation.soaring
2G
Dan
The ground plane you install would normally be inside the CF fuselage.. And the antenna manufacture or glider manufacturer should provide instructions on how to do this properly. A part of the point of that aluminium plate or foil tape ground plane is to help with a good connection to the coax cable ground. In some cases you might scuff the inside of the fueslage to help make additional electrical connection to the carbon fibre weave. *Follow the directions your glider manufacturer provides.* A plate especially can also help provide a good solid surface for antenna lock washers to engage with. Clearly here the CF will act in part as a ground plane (even without a good direct electrical connection, but by backing it with a better conductor with good connection to the coax you are helping things along).
Yes.
PowerFlarm Antenna Locations on Carbon Fuselage Dan Marotta Soaring 9 August 15th 19 08:38 PM
ASW27 Trasponder Antenna Installation Inside Fuselage. Paul Birkett Soaring 45 January 8th 18 03:31 AM
ASW-24 - Transponder Cable Routing in Fuselage [email protected] Soaring 6 February 3rd 15 05:00 PM
Transponder Antenna Placement Fuselage Bottom - Minimize Damage?Exact Location WaltWX[_2_] Soaring 9 January 19th 15 11:00 PM
Transponder and antenna Paolo Soaring 1 March 6th 04 03:32 AM
