Well here is a link to a picture of a Ventus with the transponder antenna located as per Schempp Hirth.
Seems to work well only is straight flight. In any banking flight, the antenna is shadowed by the fuselage and/or wings. Maybe a location on the turtledeck is better ? https://www.airliners.net/photo/-/Sc...HgcaJ1/QJ2lC9A Dan |
On Saturday, December 28, 2019 at 9:23:02 PM UTC-8, wrote:
Well here is a link to a picture of a Ventus with the transponder antenna located as per Schempp Hirth. Seems to work well only is straight flight. In any banking flight, the antenna is shadowed by the fuselage and/or wings. Maybe a location on the turtledeck is better ? https://www.airliners.net/photo/-/Sc...HgcaJ1/QJ2lC9A Dan Thanks for the photo, ouch yep that looks like a dopey position, if above is the only other practical option I'd do that. |
On Saturday, December 28, 2019 at 10:27:43 PM UTC-8, Darryl Ramm wrote:
On Saturday, December 28, 2019 at 9:23:02 PM UTC-8, wrote: Well here is a link to a picture of a Ventus with the transponder antenna located as per Schempp Hirth. Seems to work well only is straight flight. In any banking flight, the antenna is shadowed by the fuselage and/or wings. Maybe a location on the turtledeck is better ? https://www.airliners.net/photo/-/Sc...HgcaJ1/QJ2lC9A Dan Thanks for the photo, ouch yep that looks like a dopey position, if above is the only other practical option I'd do that. I've got a Ventus 2c with a flexible antenna positioned exactly like that, per SH recommendations, and have passed a dozen ADS-B checks in the last year, with lots of low altitude yanking and banking. |
Do you have the Blade type antenna or the cylinder/ball one ?
Thanks, Dan |
On Sunday, December 29, 2019 at 9:47:45 PM UTC-8, wrote:
Do you have the Blade type antenna or the cylinder/ball one ? Thanks, Dan Flexible, similar to the one linked (not HpH branded, as far as I know). https://wingsandwheels.com/hph-trans...r-antenna.html |
PowerFlarm Antenna Locations on Carbon Fuselage | Dan Marotta | Soaring | 9 | August 15th 19 08:38 PM |
ASW27 Trasponder Antenna Installation Inside Fuselage. | Paul Birkett | Soaring | 45 | January 8th 18 03:31 AM |
ASW-24 - Transponder Cable Routing in Fuselage | [email protected] | Soaring | 6 | February 3rd 15 05:00 PM |
Transponder Antenna Placement Fuselage Bottom - Minimize Damage?Exact Location | WaltWX[_2_] | Soaring | 9 | January 19th 15 11:00 PM |
Transponder and antenna | Paolo | Soaring | 1 | March 6th 04 03:32 AM |
