5Z wrote on 12/29/2019 10:11 AM:
On Friday, December 27, 2019 at 5:22:04 PM UTC-8, wrote: I put mine on a turtle deck on my ASW 27 and it works fine no issues with anyone seeing me or even worrying about it I really like the fact that it's there and was really easy to install compared to down by the gear Long ago someone (I believe from Arizona) posted here about doing some research by talking to folks very familiar with FAA radar design about putting the transponder antenna on top of the fuselage. The conclusion was that if very near and above the radar site, the signal *might* be blocked. Other than that, it should be fine. Since we do a lot of turning, the antennal will be blocked for times anyway. One reason for a transponder is to be seen by large aircraft TCAS, it's more likely they will be descending on a collision course, so having the antenna on top is a better idea.... Near airports, airliners are descending and ascending; in between they are above 18K. In our area, the C-17s cruise high and low; the low ones (2000' agl) are never a problem, but the other ones do cross our normal altitudes at least twice each flight. I'm skeptical that they are mostly descending, but I think their TCAS can easily detect us when they get within a few miles, regardless of the top/bottom location. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 |
PowerFlarm Antenna Locations on Carbon Fuselage | Dan Marotta | Soaring | 9 | August 15th 19 08:38 PM |
ASW27 Trasponder Antenna Installation Inside Fuselage. | Paul Birkett | Soaring | 45 | January 8th 18 03:31 AM |
ASW-24 - Transponder Cable Routing in Fuselage | [email protected] | Soaring | 6 | February 3rd 15 05:00 PM |
Transponder Antenna Placement Fuselage Bottom - Minimize Damage?Exact Location | WaltWX[_2_] | Soaring | 9 | January 19th 15 11:00 PM |
Transponder and antenna | Paolo | Soaring | 1 | March 6th 04 03:32 AM |
