https://en.wikipedia.org/wiki/Macchi_C.200
The Macchi C.200 Saetta (Italian: Lightning), or MC.200, was a fighter aircraft developed and manufactured by Aeronautica Macchi in Italy. It was operated in various forms by the Regia Aeronautica (Italian Air Force) who used the type throughout the Second World War. The C.200 was designed by Mario Castoldi, Macchi's lead designer, to serve as a modern monoplane fighter aircraft, furnished with retractable landing gear and powered by a radial engine. It possessed excellent maneuverability and the C.200's general flying characteristics left little to be desired. Stability in a high-speed dive was exceptional, but it was underpowered and underarmed in comparison to its contemporaries. Early on, there were a number of crashes caused by stability problems, nearly resulting in the grounding of the type, which was ultimately addressed via aerodynamic modifications to the wing. From the time Italy entered the Second World War on 10 June 1940, until the signing of the armistice of 8 September 1943, the C. 200 flew more operational sorties than any other Italian aircraft. The Saetta saw operational service in Greece, North Africa, Yugoslavia, across the Mediterranean and the Soviet Union (where it obtained an excellent kill to loss ratio of 88 to 15). Its very strong all-metal construction and air-cooled engine made the aircraft ideal for conducting ground attack missions; several units flew it as a fighter-bomber. Over 1,000 aircraft had been constructed by the end of the war. The Macchi C.200 was a modern all-metal cantilever low-wing monoplane, which was equipped with retractable landing gear and an enclosed cockpit. The fuselage was of semi-monocoque construction, with self-sealing fuel tanks under the pilot's seat, and in the centre section of the wing. The distinctive "hump" elevated the cockpit to provide the pilot with an unobstructed view over the engine. The wing had an advanced system whereby the hydraulically actuated flaps were interconnected with the ailerons, so that when the flaps were lowered the ailerons drooped as well. The Macchi provided an outstanding field of view, since the cockpit was partially open and placed on the hump of the fuselage. As a result of its ultimate load factor of 15.1, it could reach speeds as fast as 500 m.p.h (True Air Speed) during dives. According to aviation author Jeffrey L. Ethell, upon its entry into service, the Supermarine Spitfire was the only Allied fighter that was capable of out-climbing the Saetta; however, this viewpoint was erroneous. Power was provided by the 650 kW (870 hp) Fiat A.74 radial engine, although Castoldi preferred inline engines, and had used them to power all of his previous designs. With "direttiva" (Air Ministry Specification) of 1932, Italian industrial leaders had been instructed to concentrate solely on radial engines for fighters, due to their superior reliability. The A.74 was a re-design of the American Pratt & Whitney R-1830 SC-4 Twin Wasp, performed by engineers Tranquillo Zerbi and Antonio Fessia, and held the distinction of being the only Italian-built engine that could provide a level of reliability comparable to Allied designs. The licence-built A.74 engine could be problematic. In late spring 1941, 4° Stormo's Macchi C.200s then based in Sicily, had all the A.74s produced by the Reggiane factory replaced because they were defective units. The elite unit had to abort many missions against Malta due to engine problems. While some figures considered the Macchi C.200 to have been underpowered, the air-cooled radial engine provided some pilot protection during strafing missions. Consequently, the C.200 was often used as a cacciabombardiere (fighter-bomber). Moreover, it was maneuverable and had a sturdy all-metal construction. Role Fighter Manufacturer Aeronautica Macchi Designer Mario Castoldi First flight 24 December 1937 Introduction 1939 Retired 1947 Primary user Regia Aeronautica Number built 1,151 + 2 Prototypes Developed into Macchi C.202 The C.200 played no role in Italy's brief action during the Battle of France. The first C.200s to make their combat debut were those of the 6° Gruppo Autonomo C.T. led by Tenente Colonnello (Wing Commander) Armando Francois. This squadron was based at the Sicilian airport of Catania Fontanarossa. A Saetta from this unit was the first C.200 to be lost in combat when, on 23 June 1940, 14 C.200s (eight from 88a Squadriglia, five from 79a Squadriglia and one from 81a Squadriglia) that were escorting 10 Savoia-Marchetti SM.79s from 11° Stormo were intercepted by two Gloster Gladiators. Gladiator No.5519, piloted by Flt Lt George Burges, jumped the bombers but was in turn attacked by a C.200 flown by Sergente Maggiore Lamberto Molinelli of 71a Squadriglia over the sea off Sliema. The Macchi overshot four or five times the more agile Gladiator which eventually shot down the Saetta. In September 1940, the C.200s of 6° Gruppo conducted their first offensive operations in support of wider Axis efforts against the Mediterranean island of Malta, escorting Junkers Ju 87 dive-bombers. Only on 1 November 1940 were the C.200s credited with their first kill. A British Sunderland on a reconnaissance mission was sighted and attacked just outside Augusta by a flight of Saettas on patrol. With the arrival towards the end of December 1940 of X Fliegerkorps in Sicily, the C.200s were assigned escort duty for I/StG.1 and II/StG.2 Ju 87 bombers attacking Malta, as the Stukas did not have adequate fighter cover until the arrival of 7./JG26's Bf 109s. British air power in the theatre also intensified, chief amongst these being the Hawker Hurricane fighter, which forced a redeployment of Italian forces in response. Although considered to be inferior to the Hurricane in terms of speed, the C.200 had the advantage in terms of manoeuvrability, turn radius, and climb rate. According to aviation author Bill Gunston, the C.200 proved effective against the Hurricane, delivering outstanding dogfight performance without any vices. While the Hurricane was faster at sea level (450 km/h/280 mph vs the C.200's 430 km/h/270 mph), the Saetta could reach more than 500 km/h (310 mph) at 4,500 m (14,800 ft), although speed dropped off at altitude: 490 km/h (300 mph) at 6,000 m (19,700 ft) and 350 km/h (220 mph) at 7,000 m (23,000 ft) with a maximum ceiling of 8,800 m (29,000 ft). Comparative speeds of the Hurricane Mk I was 505 km/h (314 mph) at 5,000 m (16,400 ft) and 528 km/h (328 mph) at 6,000 m (19,700 ft). Over 5,000 m (16,400 ft) and at very low levels, only the huge Vokes (anti-sand) air filter fitted to the "tropical" variants slowed the Hurricane Mk II to Macchi levels. Although the Macchi C.200 was more agile than the Hurricane, it carried a lighter armament than its British adversary. North Africa Fitted with dust filters and designated C.200AS, the Saetta saw extensive use in North Africa, greater than any other theatre of action. The Macchi's introduction was not initially well received by pilots when in 1940, the first C.200 unit, 4° Stormo replaced the type with the C.R.42. The first combat missions were flown as escorts for Savoia-Marchetti SM.79 bombers attacking Malta in June 1940, where one C.200 was claimed by a Gladiator. On 11 June 1940, second day of war for Italy, the C.200s of 79a Squadriglia encountered one of the Sea Gladiators which had been scrambled from Hal Far, Malta. Officer W.J. Wood claimed Tenente Giuseppe Pesola had been shot down, but the Italian pilot came back unscathed to his base. Specifications (Macchi C.200 early series) General characteristics Crew: 1 Length: 8.25 m (27 ft 1 in) Wingspan: 10.58 m (34 ft 9 in) Height: 3.05 m (10 ft 0 in) Wing area: 16.82 m2 (181.0 sq ft) Airfoil: root: NACA 23018 (modified); tip: NACA 23009 (modified) Empty weight: 1,964 kg (4,330 lb) Gross weight: 2,200 kg (4,850 lb) Max takeoff weight: 2,395 kg (5,280 lb) Powerplant: 1 × Fiat A.74 R.C.38 14-cylinder air-cooled radial engine, 650 kW (870 hp) at 2,520 rpm for takeoff Propellers: 3-bladed variable-pitch propeller Performance Maximum speed: 504 km/h (313 mph; 272 kn) Stall speed: 128 km/h (80 mph; 69 kn) Range: 570 km (354 mi; 308 nmi) Service ceiling: 8,900 m (29,200 ft) Rate of climb: 15.3 m/s (3,010 ft/min) Time to altitude: 5,000 m (16,000 ft) in 5 minutes 52 seconds Wing loading: 131.7 kg/m2 (27.0 lb/sq ft) Power/mass: 0.286 kW/kg (0.174 hp/lb) Take-off run: 260 m (850 ft) Landing run: 300 m (980 ft) Armament 2× 12.7 mm (0.500 in) Breda-SAFAT machine guns, 370 rpg Some aircraft were field-modified to carry up to 8× 15 kg (33 lb), 2× 50 kg (110 lb), 2× 100 kg (220 lb), or 2× 150 kg (330 lb) bombs under the wings * |
Macchi C.202 pics 3 [6/7] - RA-Macchi-C_202-54-Stormo-16-Gruppo-168SA-168-6-La-Souka-Tunis-1943.jpg (1/1) | Miloch | Aviation Photos | 0 | February 5th 19 03:56 PM |
Macchi C.202 pics 2 [5/6] - Italian fighter Macchi C.202 «Folgore» at the airport in Tripoli.jpg (1/1) | Miloch | Aviation Photos | 0 | February 5th 19 03:54 PM |
Macchi C.202 pics 2 [3/6] - early Macchi C.202 (no radio mast) of 81ª Squadriglia, 6° Gruppo, 1° Stormo CT.jpg (1/1) | Miloch | Aviation Photos | 0 | February 5th 19 03:54 PM |
Macchi C.205 pics [4/8] - ANR-Macchi-C_205-Veltro-101-Gruppo-208SA-landing-Lecca-01.jpg (1/1) | Miloch | Aviation Photos | 0 | September 2nd 18 02:46 PM |
Macchi C.200 pics 2 [01/11] - Formation of the Macchi 200 bomber escort, probably on a mission to Malta and Tobruk.jpg (1/1) | Miloch | Aviation Photos | 0 | November 2nd 17 02:51 PM |
