Locating Transponder Antenna on top of the fuselage instead of under it.
Old December 30th 19, 10:52 PM posted to rec.aviation.soaring
[email protected][_2_]
Default Locating Transponder Antenna on top of the fuselage instead ofunder it.
O
And since you asked about different style 1/4 wave dipoles. The rods, blades etc. should all behave the same from a RF viewpoint. They are effectively the same internally. Rods/single attach point style antennas may be easier to attach/mount on curved surfaces, but have higher drag than a blade if that small drag worries you. I've also seen A&Ps recommend the rod style so that if you do manage to crunch it will bend and hopefully do less damage to the fuselage/finish.
Transponder rod antennas spec drag at .41 lbs at 250 MPH and blade antennas at .09 lbs at 250 MPH. That seems to be a big difference but anyone have a comment to what this measures in the gliding world?
Old December 30th 19, 11:23 PM posted to rec.aviation.soaring
Darryl Ramm
On Monday, December 30, 2019 at 2:52:49 PM UTC-8, wrote:
O
The simplest answer: parasitic drag ~ V^2. So at (100mph/250mph)^2 * 0.4 = ~0.07 lb. = ~1 oz.
I suspect this has been flogged to death on r.a.s. before.
"Honey I need a new glider with a tail mounted transponder antenna because it's lower drag. And I'll win more contests. Honey?" :-)
Old December 31st 19, 12:17 PM posted to rec.aviation.soaring
India November[_2_]
Although the faired blade antenna has a theoretical drage coefficient less than a rod, in practice you have to align the blade with the local flow in the area of the attachment point. If the blade is not parallel with the streamlines, I suspect it potentially could add more drag than a plain ole' rod.
Old December 31st 19, 05:04 PM posted to rec.aviation.soaring
I will let you know what I found and what decided.
Dan
Old January 1st 20, 02:32 PM posted to rec.aviation.soaring
India November[_2_]
I am thinking of the theoretical advantage in drag coefficient of a blade vs rod antenna which holds for any speed.
Old January 1st 20, 08:36 PM posted to rec.aviation.soaring
MNLou
Assuming, as previously stated, that the blade antenna is aligned with the airflow around the fuselage at that point.
I would think that the drag of a misaligned blade antenna could be significantly higher than the perfect alignment drag.
For that reason, I'm personally going with a rod and ball antenna. The manufacturer's recommendation for mounting a transponder antenna is in an area where I have no idea how the air really flows.
Does anyone know if the difference between a perfectly aligned blade antenna and a rod and ball antenna is at all significant at, say, 100 kts airspeed?
Lou
Old January 1st 20, 08:43 PM posted to rec.aviation.soaring
Dan Marotta
Just anecdotal evidence here, but my Stemme came with a rod and ball
transponder antenna under the nose bowl.Â* I mounted a blade type antenna
about 6 inches aft of that for the Flarm B.Â* I haven't noticed any
difference in flying qualities, drag, etc.Â* Maybe it's measurable but
who cares?Â* I'm not in contention for a world record or title.
Lou
Dan, 5J
Old January 1st 20, 09:08 PM posted to rec.aviation.soaring
From the Aircraft Spruce website, the drag spec on a rod and ball transponder antenna is listed as 0.41 lbs. at 250 kts. The blade type lists as 0.09 lbs. at 250 knots. Drag increases by the square of the speed, so at half the speed (125 knots), the drag is around 1/4 the numbers listed. If you are concerned about the .0225 lbs. in extra drag vs. the .01025 lbs., buy the blade type and keep the yaw string straight. You will probably increase your final glide numbers by at least a couple of yards.
Old January 2nd 20, 01:25 AM posted to rec.aviation.soaring
Mark Mocho wrote:
"If you are concerned about the .0225 lbs. in extra drag vs. the .01025 lbs.., buy the blade type and keep the yaw string straight. You will probably increase your final glide numbers by at least a couple of yards."
But Mark, the blade type just looks cool! Especially when mounted on top! 😛😂😵
PowerFlarm Antenna Locations on Carbon Fuselage Dan Marotta Soaring 9 August 15th 19 08:38 PM
ASW27 Trasponder Antenna Installation Inside Fuselage. Paul Birkett Soaring 45 January 8th 18 03:31 AM
ASW-24 - Transponder Cable Routing in Fuselage [email protected] Soaring 6 February 3rd 15 05:00 PM
Transponder Antenna Placement Fuselage Bottom - Minimize Damage?Exact Location WaltWX[_2_] Soaring 9 January 19th 15 11:00 PM
Transponder and antenna Paolo Soaring 1 March 6th 04 03:32 AM
