Locating Transponder Antenna on top of the fuselage instead of under it.
Old December 31st 19, 12:10 AM posted to rec.aviation.soaring
5Z
Default Locating Transponder Antenna on top of the fuselage instead ofunder it.
On Monday, December 30, 2019 at 6:44:50 AM UTC-8, Dan Marotta wrote:
In the absence of antenna diversity, I'm pretty sure all general
aviation factory built aircraft have the transponder antenna on the
bottom of the aircraft.Â* I would think the manufacturers must know
something.
When transponders first came out, the only receiver/interrogator was ground based. So anything certificated prior to TCAS, would definitely have the antenna on the bottom.
Then TCAS came along, and now ADS-B. These will interrogate/receive from any direction. So to be visible from any direction, one should probably have an antenna on top as well as bottom... And satellite based ADS-B likely demands it.
I'm sure Darryl has all the gory technical details :-) But my guess is that unless told otherwise, and considering cost of certification, etc., putting the antenna "where it's always been" is why it's on the bottom. :-)
5Z
PowerFlarm Antenna Locations on Carbon Fuselage Dan Marotta Soaring 9 August 15th 19 08:38 PM
ASW27 Trasponder Antenna Installation Inside Fuselage. Paul Birkett Soaring 45 January 8th 18 03:31 AM
ASW-24 - Transponder Cable Routing in Fuselage [email protected] Soaring 6 February 3rd 15 05:00 PM
Transponder Antenna Placement Fuselage Bottom - Minimize Damage?Exact Location WaltWX[_2_] Soaring 9 January 19th 15 11:00 PM
Transponder and antenna Paolo Soaring 1 March 6th 04 03:32 AM
