Locating Transponder Antenna on top of the fuselage instead of under it.
Old December 31st 19, 12:17 PM posted to rec.aviation.soaring
India November[_2_]
Default Locating Transponder Antenna on top of the fuselage instead ofunder it.
Although the faired blade antenna has a theoretical drage coefficient less than a rod, in practice you have to align the blade with the local flow in the area of the attachment point. If the blade is not parallel with the streamlines, I suspect it potentially could add more drag than a plain ole' rod.
Old December 31st 19, 05:04 PM posted to rec.aviation.soaring
I will let you know what I found and what decided.
Dan
PowerFlarm Antenna Locations on Carbon Fuselage Dan Marotta Soaring 9 August 15th 19 08:38 PM
ASW27 Trasponder Antenna Installation Inside Fuselage. Paul Birkett Soaring 45 January 8th 18 03:31 AM
ASW-24 - Transponder Cable Routing in Fuselage [email protected] Soaring 6 February 3rd 15 05:00 PM
Transponder Antenna Placement Fuselage Bottom - Minimize Damage?Exact Location WaltWX[_2_] Soaring 9 January 19th 15 11:00 PM
Transponder and antenna Paolo Soaring 1 March 6th 04 03:32 AM
