Locating Transponder Antenna on top of the fuselage instead of under it.
Old January 1st 20, 08:43 PM posted to rec.aviation.soaring
Dan Marotta
Default Locating Transponder Antenna on top of the fuselage instead ofunder it.
Just anecdotal evidence here, but my Stemme came with a rod and ball
transponder antenna under the nose bowl.Â* I mounted a blade type antenna
about 6 inches aft of that for the Flarm B.Â* I haven't noticed any
difference in flying qualities, drag, etc.Â* Maybe it's measurable but
who cares?Â* I'm not in contention for a world record or title.
On 1/1/2020 1:36 PM, MNLou wrote:
On Wednesday, January 1, 2020 at 8:32:48 AM UTC-6, India November wrote:
I am thinking of the theoretical advantage in drag coefficient of a blade vs rod antenna which holds for any speed.
Assuming, as previously stated, that the blade antenna is aligned with the airflow around the fuselage at that point.
I would think that the drag of a misaligned blade antenna could be significantly higher than the perfect alignment drag.
For that reason, I'm personally going with a rod and ball antenna. The manufacturer's recommendation for mounting a transponder antenna is in an area where I have no idea how the air really flows.
Does anyone know if the difference between a perfectly aligned blade antenna and a rod and ball antenna is at all significant at, say, 100 kts airspeed?
Lou
Dan, 5J
PowerFlarm Antenna Locations on Carbon Fuselage Dan Marotta Soaring 9 August 15th 19 08:38 PM
ASW27 Trasponder Antenna Installation Inside Fuselage. Paul Birkett Soaring 45 January 8th 18 03:31 AM
ASW-24 - Transponder Cable Routing in Fuselage [email protected] Soaring 6 February 3rd 15 05:00 PM
Transponder Antenna Placement Fuselage Bottom - Minimize Damage?Exact Location WaltWX[_2_] Soaring 9 January 19th 15 11:00 PM
Transponder and antenna Paolo Soaring 1 March 6th 04 03:32 AM
