Locating Transponder Antenna on top of the fuselage instead of under it.
Old January 1st 20, 09:08 PM posted to rec.aviation.soaring
Default Locating Transponder Antenna on top of the fuselage instead ofunder it.
From the Aircraft Spruce website, the drag spec on a rod and ball transponder antenna is listed as 0.41 lbs. at 250 kts. The blade type lists as 0.09 lbs. at 250 knots. Drag increases by the square of the speed, so at half the speed (125 knots), the drag is around 1/4 the numbers listed. If you are concerned about the .0225 lbs. in extra drag vs. the .01025 lbs., buy the blade type and keep the yaw string straight. You will probably increase your final glide numbers by at least a couple of yards.
Old January 2nd 20, 01:25 AM posted to rec.aviation.soaring
Mark Mocho wrote:
"If you are concerned about the .0225 lbs. in extra drag vs. the .01025 lbs.., buy the blade type and keep the yaw string straight. You will probably increase your final glide numbers by at least a couple of yards."
But Mark, the blade type just looks cool! Especially when mounted on top! 😛😂😵
Old January 2nd 20, 03:44 AM posted to rec.aviation.soaring
But I have flown with you, Cliff, and the drag from the antenna is only low when aligned with the airflow. Your yaw string looks like a windshield wiper! You don't go faster by using the rudder pedals like bicycle pedals.
Old January 2nd 20, 05:41 AM posted to rec.aviation.soaring
Thanks. I needed a laugh.
Old January 2nd 20, 11:44 PM posted to rec.aviation.soaring
Chris Behm
Just mount the blade antenna by the front lug only, leave it loose a bit. Cut a slight smile slot for the coax, use a bit of grease, and,voila!
Now your blade style antenna can feather with the wind, netting you the least amount of drag possible.
Old January 3rd 20, 01:50 AM posted to rec.aviation.soaring
jfitch
Why not mount it on the side of the fuselage and use it as an angle of attack sensor as well?
Old January 3rd 20, 02:16 AM posted to rec.aviation.soaring
George Haeh
Don't forget to properly mass balance any movable surface.
Old January 3rd 20, 03:09 AM posted to rec.aviation.soaring
Jonathan St. Cloud
And get Boeing to design you a MCAS so you are always safe from stall.
PowerFlarm Antenna Locations on Carbon Fuselage Dan Marotta Soaring 9 August 15th 19 08:38 PM
ASW27 Trasponder Antenna Installation Inside Fuselage. Paul Birkett Soaring 45 January 8th 18 03:31 AM
ASW-24 - Transponder Cable Routing in Fuselage [email protected] Soaring 6 February 3rd 15 05:00 PM
Transponder Antenna Placement Fuselage Bottom - Minimize Damage?Exact Location WaltWX[_2_] Soaring 9 January 19th 15 11:00 PM
Transponder and antenna Paolo Soaring 1 March 6th 04 03:32 AM
