Locating Transponder Antenna on top of the fuselage instead of under it.
Old January 3rd 20, 02:16 AM posted to rec.aviation.soaring
George Haeh
Default Locating Transponder Antenna on top of the fuselage instead ofunder it.
Don't forget to properly mass balance any movable surface.
  #72
Old January 3rd 20, 03:09 AM posted to rec.aviation.soaring
Jonathan St. Cloud
On Thursday, January 2, 2020 at 5:51:01 PM UTC-8, jfitch wrote:
On Thursday, January 2, 2020 at 3:44:53 PM UTC-8, Chris Behm wrote:
Just mount the blade antenna by the front lug only, leave it loose a bit. Cut a slight smile slot for the coax, use a bit of grease, and,voila!
Now your blade style antenna can feather with the wind, netting you the least amount of drag possible.
Why not mount it on the side of the fuselage and use it as an angle of attack sensor as well?
And get Boeing to design you a MCAS so you are always safe from stall.
  #73
Old January 3rd 20, 04:35 AM posted to rec.aviation.soaring
Chris Behm
If the pivot point was in the prefect place, then you wouldn't need to. Maybe fiberglass cover with counterbalance?
Thanks for indulging my silliness gents.
I'll stop spamming the original poster here. Time to be serious. Happy New Year all of you.
  #74
Old January 14th 20, 05:55 PM posted to rec.aviation.soaring
I have decided to install the transponder blade antenna on top of the fuselage, behind the engine doors, as per Schempp Hirth TN.
Dan
  #75
Old January 14th 20, 09:14 PM posted to rec.aviation.soaring
[email protected][_2_]
Dan
Dan, what is the TN number you refer to?
Terry
  #76
Old January 15th 20, 12:49 AM posted to rec.aviation.soaring
It is TN 845-46
Dan
PowerFlarm Antenna Locations on Carbon Fuselage Dan Marotta Soaring 9 August 15th 19 08:38 PM
ASW27 Trasponder Antenna Installation Inside Fuselage. Paul Birkett Soaring 45 January 8th 18 03:31 AM
ASW-24 - Transponder Cable Routing in Fuselage [email protected] Soaring 6 February 3rd 15 05:00 PM
Transponder Antenna Placement Fuselage Bottom - Minimize Damage?Exact Location WaltWX[_2_] Soaring 9 January 19th 15 11:00 PM
Transponder and antenna Paolo Soaring 1 March 6th 04 03:32 AM
