On Sunday, January 12, 2020 at 8:27:19 AM UTC-8, Dan Marotta wrote:
...or just look at the section lines on then ground.Â* If the sun is shining, it's pretty easy to guess the cardinal directions. On 1/11/2020 8:58 PM, Eric Greenwell wrote: Charles Longley wrote on 1/11/2020 6:59 PM: Pfft compass what’s that? Look out the canopy. Not a good option in Kansas! You are spoiled by flying where there are mountains to guide you. In Kansas, look at the GPS track when you want to know direction. Or pull out your iPhone, and use the compass app. -- Dan, 5J Garmin's only precaution about the placement of multiple GPS antennas is the potential effect of one antenna shadowing another: 3c. To minimize the effects of shadowing at 5° elevation angles, the GPS antenna should be mounted no closer than 6 inches (edge to edge) from other antennas, including passive antennas such as another GPS antenna or XM antenna. http://static.garmin.com/pumac/GA35G...structions.pdf And if you want to share a single antenna with multiple instruments you can get a splitter (albeit not cheaply!): https://www.gpssource.com/collections/gps-splitter Tom |
| Thread Tools | |
| Display Modes | |
| Antennas! Get yer antennas here! | Bob (not my real pseudonym) | Aviation Photos | 0 | March 3rd 11 05:38 AM |
| Antennas | [email protected] | Home Built | 1 | February 19th 09 08:32 PM |
| Aircraft antennas | ccwillwerth | Home Built | 23 | October 26th 06 11:30 PM |
| Antennas | Terry | Home Built | 3 | April 24th 05 07:42 PM |
| Antennas | Terry | Home Built | 3 | April 22nd 05 04:14 AM |
