Locating Transponder Antenna on top of the fuselage instead of under it.
  #30
Old January 14th 20, 09:14 PM posted to rec.aviation.soaring
[email protected][_2_]
Default Locating Transponder Antenna on top of the fuselage instead ofunder it.
On Tuesday, January 14, 2020 at 11:55:32 AM UTC-6, wrote:
I have decided to install the transponder blade antenna on top of the fuselage, behind the engine doors, as per Schempp Hirth TN.
Dan
Dan, what is the TN number you refer to?
Terry
PowerFlarm Antenna Locations on Carbon Fuselage Dan Marotta Soaring 9 August 15th 19 08:38 PM
ASW27 Trasponder Antenna Installation Inside Fuselage. Paul Birkett Soaring 45 January 8th 18 03:31 AM
ASW-24 - Transponder Cable Routing in Fuselage [email protected] Soaring 6 February 3rd 15 05:00 PM
Transponder Antenna Placement Fuselage Bottom - Minimize Damage?Exact Location WaltWX[_2_] Soaring 9 January 19th 15 11:00 PM
Transponder and antenna Paolo Soaring 1 March 6th 04 03:32 AM
