Shenyang J-8
https://en.wikipedia.org/wiki/Shenyang_J-8
The Shenyang J-8 (Chinese: ?-8; NATO reporting name: Finback) is a high-speed, high-altitude Chinese-built single-seat interceptor fighter aircraft. The effort to develop an all-weather interceptor began in full in 1964 and this produced the first Chinese-designed and built jet fighter to combat new, high altitude threats such as the B-58 Hustler bomber, F-105 Thunderchief fighter-bomber and Lockheed U-2 spy plane. In 1964 the People's Liberation Army Air Force requested an aircraft from Shenyang Aircraft Corporation and the 601 Institute to develop a fighter/interceptor to counter bombers and spy planes as the newly introduced Chengdu J-7 (a reverse engineered MiG-21) was incapable of doing so. The prototype took its maiden flight in 1969. Despite the mid 1960s origins of the J-8, due to the political turmoil of the Great Proletarian Cultural Revolution, the J-8 was not produced until 1979 and entered service in 1980. Its basic configuration resembles an enlargement of the delta-winged J-7, utilizes two Liyang (LMC) Wopen-7A turbojet engines, and features a maximum speed of Mach 2.2. The twin engined J-8 competed with rival Chengdu Aircraft Industry Group's single, turbofan powered engine, canard-delta J-9 project and ultimately emerged as the victor largely due to the existing availability of the former's MiG-21 based powerplant and proven layout, while the J-9 project was cancelled in 1980 due to difficulty in creating a suitably powerful engine. Despite entering service relatively recently, it was comparable to many older Soviet fighter designs, with limited maneuverability. The original combat avionics package was soon replaced with an all-weather capability in aircraft designated J-8I (Finback-A). The J-8I (later redesignated as the J-8A) received a new gun sight, onboard computer, new cockpit design and redesigned ejection escape system and oxygen supply system. The gun armament was also changed from two 30 mm cannons to a single 23 mm twin-barreled cannon and the PL-5 short ranged AAM was also equipped. The later J-8E featured improved electronic warfare systems. The unsatisfactory performance of the J-8I led to a very short production run of 20–50 aircraft and the J-8I has slowly began being phased out as early as the 1990s. A tactical reconnaissance variant of the J-8, known as the JZ-8 was developed in the mid 1980s to take advantage of the J-8s few favourable qualities, most notably its capability of reaching high speeds and altitudes to replace the Shenyang JZ-6 in the tactical reconnaissance role. Using an under-fuselage reconnaissance pod with a KA-112A long focal-length optical camera, the JZ-8 usually operates at heights ranging from ~9,500m-15,000m during reconnaissance missions. By 1982 work began to replace the unimpressive J-8I type with a new design known as the J-8II. The new 1982 requirements from the PLAAF demanded being capable of beyond visual range combat (BVR) with the use medium ranged missiles (MRAAM) and secondary ground attack capabilities. In terms of performance, the aircraft was expected to have better aerodynamic performance at medium to low altitudes and at transonic speeds. J-8II The J-8II series appear quite different from the original J-8, with a new forward fuselage, intake ramps with splitter plates and nose structure more reminiscent of the F-4 Phantom II or Sukhoi Su-15 to house a new, more powerful radar. The J-8II is powered by two Wopen-13A (WP-13A) engines. The design and development team was led by Gu Songfen, who is also a key member of J-8I design team. It was hoped to equip the production J-8B with an American AN/APG-66(V) radar (to be dubbed the J-8C), but this proved politically impossible after the Tiananmen Square protests of 1989 so the indigenous Type 208A monopulse radar fire-control radar initially was used. Although the Type 208A was an improvement over the original J-8I radar, the Type 208A did not have true beyond visual range capabilities (The detection range of the Type 208 was 40 km) nor look-down/shoot-up ground attack capabilities, thereby falling short of the PLAAFs initial requirements and the redesign of the airframe. The J-8B was the early production batch of the new J-8II series. In addition to receiving a new radar, new engine and redesigned noses, cockpit and intake, the J-8B also benefited from a new head-up display, integrated inertial navigation system/Global positioning satellite system and TACAN technology. Later J-8Bs were equipped with the more robust KLJ-1 pulse-Doppler radar fire-control radar and radar warning receiver, theoretically giving the later batch BVR capabilities. J-8B is the second Chinese aircraft to be equipped with a data link, the first being the Chengdu J-7III, and the data link is designated as Type 483 (developed from Type 481 data link used for J-7III), which enables ground-controlled interception centres to feed directions directly to the autopilots of J-8Bs to fly "hands off" to the interception. Role Interceptor National origin China Manufacturer Shenyang Aircraft Corporation Design group Shenyang Aircraft Design Institute First flight J-8: 5 July 1969 J-8II: 12 June 1984 Introduction 1980 Status In service Primary users PLA Air Force PLA Naval Air Force Produced 1979–2010 Number built 380 Operational history There are currently over 300 J-8s of all types serving in the People's Liberation Army Air Force and People's Liberation Army Naval Air Force. The J-8 is expected to be superseded by modern Chengdu J-10 and J-11 variants in the coming years. Specifications (F-8 IIM) General characteristics Crew: 1 Length: 21.39 m (70 ft 2 in) (20.53 m (67.4 ft) excluding nose pitot probe) Wingspan: 9.344 m (30 ft 8 in) Height: 5.41 m (17 ft 9 in) Wing area: 42.2 m2 (454 sq ft) Airfoil: root: TsAGI S-12 (4.2%) ; tip: TsAGI S-12 (5%) Empty weight: 10,371 kg (22,864 lb) Gross weight: 15,288 kg (33,704 lb) Max takeoff weight: 18,879 kg (41,621 lb) Powerplant: 2 × Guizhou WP-13B afterburning turbojet engines, 47.1 kN (10,580 lbf) thrust each dry, 68.6 kN (15,430 lbf) with afterburner Performance Maximum speed: 2,300 km/h (1,429 mph; 1,242 kn) limited to M2.2 Maximum speed: Mach 2.4 Combat range: 1,000 km (621 mi; 540 nmi) radius with 3x drop tanks Combat radius with one AAR: 900 km (560 mi; 490 nmi) Service ceiling: 18,000 m (59,000 ft) g limits: +4.7 sustained at 5,000 m (16,000 ft) Thrust/weight: 0.741 lbf/lb (0.00727 kN/kg) Unstick speed: 330 km/h (210 mph; 180 kn) Take-offrun: 630 m (2,070 ft) Touchdown speed: 224 km/h (139 mph; 121 kn) Landing run: 900 m (3,000 ft) Armament 1 x 23mm Type 23-3 (Gsh-23) cannon * |
Similar Threads | ||||
Shenyang J-8 pics [2/8] - Chinese-fighter-planes from left to right you can ID Shenyang J-11, Chengdu J-10, Shenyang J-8II, Shenyang J-8, Chengdu J-7, Shenyang J-6, Shenyang JJ-2. Front row Xian JH-7A, Nanchang A5.jpg (1/1) | Miloch | Aviation Photos | 2 | February 22nd 19 04:13 PM |
Shenyang J-8 pics 2 [6/8] - Shenyang J-8II in flight. This plane collided with a US Navy EP-3 Aries II in 2001.jpg (1/1) | Miloch | Aviation Photos | 0 | February 20th 19 03:07 PM |
Shenyang J-8 pics 2 [5/8] - Shenyang J-8B at Datang Shan aviation museum.jpg (1/1) | Miloch | Aviation Photos | 0 | February 20th 19 03:07 PM |
Shenyang J-8 pics 2 [3/8] - Shenyang F-8II, armed with air-to-air missiles and six bombs on a centreline tri-rack..jpg (1/1) | Miloch | Aviation Photos | 0 | February 20th 19 03:07 PM |
Shenyang J-31 pics [06/13] - New Shenyang J-31 photos 9.jpg (1/1) | Miloch | Aviation Photos | 0 | October 10th 17 03:43 PM |
