WGC Final Report, John Good
Old January 20th 20, 11:01 PM posted to rec.aviation.soaring
Tango Eight
Default WGC Final Report, John Good
On Monday, January 20, 2020 at 3:49:03 PM UTC-5, Tijl wrote:
- In your Flarm, set your ICAO 24-bit code to "0". Each time you power up your Flarm, your Flarm-Radio ID will be newly randomly generated.
If so, this is quite the undocumented Easter egg. Can anyone confirm?
T8
Old January 20th 20, 11:09 PM posted to rec.aviation.soaring
Tijl
T8
It's not undocumented.
https://flarm.com/flarm-firmware-v6-40-released/
It works if you use the online Flarm configuration tool:
https://flarm.com/support/tools-soft...guration-tool/
Quote:
"ICAO 24-bit aircraft address, hexadecimal
Official 24-bit ICAO aircraft address in hexadecimal notation, as issued by local CAA. It consists of six hexadecimal characters (0-9, a-f) and can be obtained from the aircraft papers. Must match the address configured in the Mode-S transponder. If the aircraft does not have a Mode-S transponder, it's possible to leave the field empty to use the device specific radio id. Enter "0" (zero) for random id (not recommended, will make Search and Rescue (SAR) very difficult)."
Old January 20th 20, 11:21 PM posted to rec.aviation.soaring
Tango Eight
T8
Official 24-bit ICAO aircraft address in hexadecimal notation, as issued by local CAA. It consists of six hexadecimal characters (0-9, a-f) and can be obtained from the aircraft papers. Must match the address configured in the Mode-S transponder. If the aircraft does not have a Mode-S transponder, it's possible to leave the field empty to use the device specific radio id.. Enter "0" (zero) for random id (not recommended, will make Search and Rescue (SAR) very difficult)."
Thank you...
T8
Old January 21st 20, 12:23 AM posted to rec.aviation.soaring
mart mart is offline
Junior Member
First recorded activity by AviationBanter: Jan 2007
I completely agree that it should be pilot skills and not technology that determines the winners.
Your idea is unfortunately very easy to circumvent, put someone in a car near the end of the runway at launch time with a reciever and write down code and rego.
I would more go for random turnpoints in a circle so that every pilot flies the same distance but you wont know if the pilot you see has done more or less of the task than you did.
Old January 21st 20, 12:36 AM posted to rec.aviation.soaring
John Foster
I think it could simplify a lot of things if they changed the rules to be more like sailboat racing. The start line opens at a specific time, and whoever crosses the line first is the winner. None of this delayed start stuff. Everyone is racing against each other in real time. The guys behind can see where the leaders are climbing, and maybe make up some time, but in order to win, you have to be in front. Much like they do in SGP racing. That format just makes more sense to me. I realize it is quite a bit different from how things have been done for many years, but it could eliminate a lot of the advantages folks would get from this whole live-tracking thing.
Old January 21st 20, 01:11 AM posted to rec.aviation.soaring
I think it could simplify a lot of things if they changed the rules to be more like sailboat racing. The start line opens at a specific time, and whoever crosses the line first is the winner. None of this delayed start stuff. Everyone is racing against each other in real time. The guys behind can see where the leaders are climbing, and maybe make up some time, but in order to win, you have to be in front. Much like they do in SGP racing. That format just makes more sense to me. I realize it is quite a bit different from how things have been done for many years, but it could eliminate a lot of the advantages folks would get from this whole live-tracking thing..
The size of the field matters. SGP has relatively small field intentionally..
I flew in one of the first "bomb burst" starts about 25 years ago. There were about 50 ships, all at cloud base when the go signal was sent. We almost all came back saying that we never wanted to do that again.
This concept also puts everyone in one big gaggle which can be highly dangerous.
Been there - done that.
In my view the solution is to work to make FLARM the collision avoidance tool it is meant to be, and do whatever can be done to stop tracking and minimize the benefits of FLARM radar. Start with option for no ID. Kill climb rate information. Make range only what it needs to be for collision avoidance. Stealth does some of this.
UH
Old January 21st 20, 03:16 PM posted to rec.aviation.soaring
Dave Nadler
I remember that one - terrifying.
IIRC that was also the USA intro of the DG-600, for sale by mid-contest...
Both concentrating everyone at the start was bad AND the first few gaggles
was quite dangerous. Even in SGP format (limited number of contestants) the
starts have been much too exciting...
Old January 21st 20, 08:07 PM posted to rec.aviation.soaring
John Foster
UH
I would agree that the size of the field matters. What would the maximum size field be that you would consider safe? How much smaller is that than current class sizes in current US contests? For a world championship contest, it could be run much like a swim meet, or other such contest where you have qualifying races with elimination rounds followed by a final race. That would be quite different than how we do things today, but I think we could take a lot from how the sport of sailing does things. They also have to deal with safety issues with mass starts and traffic and changing weather conditions across the course and throughout the day. I think that this kind of format could fix many of the issues (not all though) we are wrestling with.
Old January 21st 20, 02:46 PM posted to rec.aviation.soaring
Jim White[_3_]
that=
=20
=20
car
co=
de and rego.=20
=20
fli=
o=
m=
who=
stuf=
ca=
o=
Th=
differe=
a
thing.
Distance Handicap Tasks do this great for handicap competition even with
pilot selected start time. see www.handicaptask.uk
Old January 21st 20, 12:46 AM posted to rec.aviation.soaring
Tijl
That wouldn't circumvent manual Flarm-ID changes at any given moment within the flight (with an LX9000 connection for instance).
You can also quickly power your Flarm off an on after take-off, thereby creating a new random ID.
I am sure if the IGC asks for it, FLARM can quickly bring out a feature that triggers a ID-randomizer every 15 minutes during the flight. But that would not even be necessary in my opinion.
Also, if the punishment of having a private ground-based Flarm receiver in a team is disqualification for the whole team, and if the rules on this are 100% clear and widely known, who in their right mind would do this?
2015 Nephi OLC/XC Final Report [email protected] Soaring 21 July 8th 15 10:56 PM
Day 4 at Perry and final report Frank Paynter[_2_] Soaring 0 April 25th 11 04:39 AM
Region 10 South Report: Final Day Bob D Soaring 0 August 16th 09 05:00 AM
Final Report of SSA FRTF Now Available [email protected] Soaring 2 October 28th 07 02:23 AM
Annual Report Final. "Long" NW_PILOT Piloting 22 October 28th 04 07:20 PM
