Affordable Oxygen
Old January 25th 20, 11:58 PM posted to rec.aviation.soaring
Tom BravoMike
Default Affordable Oxygen
What/where is INYK? Sorry, can't find it.
Inyokern Airport (IATA: IYK, ICAO: KIYK, FAA LID: IYK)
Got it, thanks!
Old January 27th 20, 12:23 AM posted to rec.aviation.soaring
ABO is tested for moisture on an individual cylinder basis. Medical O2 is tested for purity on a sample basis (usually one cylinder out of a 20 cylinder line). Industrial O2: each cylinder is sniff tested prior to filling to make sure no flammable gas or other stinky thing is loitering in the cylinder. No testing of industrial grade after filling.
Yes, all are filled from the same liquid O2 tank, all are pumped on the same manifold. However, the compliant filling facility does the above steps because either FAA, FDA, or CGA says that is how to do it.
It's reasonably easy to play safe: have a CGA 540 tank, get a fill from an ABO cascade manifold at the airport. It is not reasonably easy to get a "great price", especially if you fly where there is no ABO manifold available..
Old January 27th 20, 01:11 AM posted to rec.aviation.soaring
Andrew Ainslie
Ask anyone who has ever done a decent physics class what happens to moisture when you compress a wet gas. It drops out. That’s why air compressors have moisture traps.
This nonsense about testing for moisture/adding moisture in medical oxygen etc etc never goes away. Compressed oxygen is incredibly dry. Any moisture in a compressed oxygen cylinder would be rolling around the bottom, not in the gas.
Easy and affordable IGC logger Senna Van den Bosch Soaring 26 May 1st 18 09:05 AM
Looking for an affordable glider.... xTrainwrecKx Soaring 4 August 17th 11 12:03 PM
Looking for an affordable glider.... xTrainwrecKx Soaring 1 August 9th 11 05:07 PM
Affordable Glider K Smith Soaring 20 July 23rd 09 07:13 AM
Affordable planes Tom Home Built 4 November 6th 08 08:59 PM
