On Wednesday, January 29, 2020 at 10:01:29 PM UTC-6, Colten Coughlin wrote:
Hello! I am looking to upgrade the panel in my 1-26, I am mainly looking for a audio vario, and a flight computer. I have been recommended a 302 or lxnav Vario, and a oudie flight computer. I would possibly still be open to other options as well though. If you or someone you know has anything for sale, if you could let me know that would be great! Thank you! Colten Coughlin I flew for years with the Cambridge 302 and an Oudie - a great combination. I also flew with a 302 and an iPaq - a cheaper, but not as good, of a combination. The 302 is a great inexpensive older electronic vario, IGC recorder, and speed to fly computer. Repair is still available through Gary Kammerer. The Oudie (SeeYou mobile) directly with the 302 with the included cabling talks. All Oudies (except the IGC model) has an "automotive" grade GPS engine but the 302 provides its much better "aviation" grade GPS data. As the 302 is an approved FAI flight recorder the Oudie comes with a utility to download the IGC file to its memory. The 302 also supplies wind data to SeeYou mobile. The Oudie is obviously highly portable to take home and play with. Early on I would suction cup (comes with the Oudie) it to my car's dash and try out the highly customizable features. Some last Oudie comments; - Go with the Oudie 2 or Oudie IGC if for no other reason than the much brighter screen. - When making changes to the configuration always create a new profile (stored on the Oudie's memory). In this way you can "recover" to an earlier profile if you screw up. And/or have multiple profiles for when you travel to other glider ports. - The Oudie easily connects to your computer to retrieve IGC flight logs. This also allows you to back up your profiles, not to mention sharing profiles with other soaring pilots. - The non-IGC Oudie's battery doesn't last very long. Best to route ship's power to it via the supplied cabling. Or use an external USB charger/battery. All in all the 302 and the Oudie is a great combo. My $0.02. Good luck. - John OHM Ω |
Colton
If your getting your 1-26 ready for xc and this years championships, let me share some of my advise. I flew records and the 1-26 championships last year simply with a 302 and an oudie igc. I didnot bother trying to load tasks into the 302, it simply functioned as a good vario. I used the oudie exclusively for working the task, recording the task, and giving me final glide info. It is very easy to create a task in the oudie and to upload competition turnpoint sets as well as downloading the flight data after your done. You should however be sure to have some aux power going to the oudie. I simply had a cig plug aux 12v receptical mounted below my panel which with a splitter kept the oudie charged and also my cell phone. You can also get the adapter cable which connects the oudie to the 302 which will also supply power to the oudie but it is not required, if you just want to use the oudie stand alone for all your navigation and task info. Dan |
On Thursday, January 30, 2020 at 10:38:59 AM UTC-5, wrote:
Colton If your getting your 1-26 ready for xc and this years championships, let me share some of my advise. I flew records and the 1-26 championships last year simply with a 302 and an oudie igc. I didnot bother trying to load tasks into the 302, it simply functioned as a good vario. I used the oudie exclusively for working the task, recording the task, and giving me final glide info. It is very easy to create a task in the oudie and to upload competition turnpoint sets as well as downloading the flight data after your done. You should however be sure to have some aux power going to the oudie. I simply had a cig plug aux 12v receptical mounted below my panel which with a splitter kept the oudie charged and also my cell phone. You can also get the adapter cable which connects the oudie to the 302 which will also supply power to the oudie but it is not required, if you just want to use the oudie stand alone for all your navigation and task info. Dan The 302 5VDC output has a maximum capacity of (iirc, check the manual) 900 mA. If you exceed this, you will overheat your 302 and cause problems, perhaps problems requiring expensive repairs. Almost any device can/will exceed 900 mA when charging, some by quite a lot. I recommend strongly against using 302 as a 5V power source for this reason, it's just too easy to screw it up. T8 |
Roger your advice T8, I would not ask the 302 to run a half or fully depleted oudie. In my system, In this years system I start with my oudie fully charged and the 302 interconnect cable is just keeping the oudie topped up. I have about 30 hours on the new system and no issues whatsoever so far. My oudie igc will run easily for 7 hours on its internal battery, but I like the insurance of having some power going to her for the longer flights.
Upgrading a used Homebuilt... | [email protected] | Home Built | 5 | August 25th 06 02:57 AM |
Upgrading your Strikefinder? | Peter MacPherson | Owning | 2 | September 1st 04 02:32 PM |
Upgrading your Strikefinder? | Peter MacPherson | Instrument Flight Rules | 0 | August 31st 04 03:45 PM |
Upgrading your Strikefinder? | Peter MacPherson | Piloting | 0 | August 31st 04 03:45 PM |
Upgrading System | Anthony Acri | Simulators | 1 | July 17th 03 03:18 AM |
