What does your maintenance manual recommend?
I used Superlube for awhile, but felt like I was getting too much fretting wear. Switched to Lucas Red n Tacky. Good wear and anti corrosion properties. https://lucasoil.com/products/grease/red-n-tacky-grease
The Schleicher manuals for my ASH-26E do not specify any grease types. The only mention of grease types is to not use molybdenum disulfide on any bearings with brass parts.
One correction to my original post, I said "scoring" I meant to say "fretting". Also, FYI my knowledgeable person noted that white lithium grease is good long term for the other lube points (control connections). Cheers, Jim J6 On Saturday, 1 February 2020 20:16:16 UTC-6, wrote: What does your maintenance manual recommend? |
The Long-Term Outlook for the U.S. Navy’s Fleet - CBO | Mike | Naval Aviation | 2 | January 28th 10 09:46 PM |
Long term storage | JSBOUGHER | Owning | 19 | October 18th 06 11:49 AM |
Easily single rigged gliders | Bill Alexander | Soaring | 12 | December 3rd 04 04:40 AM |
Composite Aircraft in the long term... | Jay Honeck | Owning | 29 | September 9th 03 12:55 AM |
Composite Aircraft in the long term... | Jay Honeck | Piloting | 29 | September 9th 03 12:55 AM |
