SeeYou incorrect waypoint altitudes
Old February 3rd 20, 12:52 AM posted to rec.aviation.soaring
Tango Eight
Default SeeYou incorrect waypoint altitudes
On Sunday, February 2, 2020 at 7:28:38 PM UTC-5, Martin Gregorie wrote:
On Sun, 02 Feb 2020 14:26:54 -0800, Tango Eight wrote:
On Sunday, February 2, 2020 at 4:12:02 PM UTC-5, Darryl Ramm wrote:
Post the actual waypoint data here... it’s just ASCII text. Then we
have a chance of seeing what is going on.
Here you go. I created this waypoint about 3 minutes ago. Use whatever
tool you like to correlate lat/long/elevation. Actual elevation closer
to 1220m....
"Brumley Mountain",,,3650.274N,08206.228W,1091.5m,1,,,,,,
Interesting, so I went looking with Google Earth...
That point seems to be on the side of a forested ridge at 1187m on the
Blue Mountains in VA.
A more obvious TP would be the rock outcrops at 35 50.11.9N 82 06.1492W,
or 3550.119N 08206.119W in Seeyou format, but of course ymmv.
Of course, this all assumes the OP didn't mean "Bromley Mountain", at the
top of the Bromley Ski Resort, Vermont at 996m (43 13'15.67"N 072
56'19.37W or 4313.157N 07256.1837W in SeeYou format) - which would be a
much more obvious turnpoint.
Martin | martin at
Gregorie | gregorie dot org
It's a ridge route. If you've done any flying of that sort, it'll make sense. If you haven't... look at the the topo and do the thought experiment.
https://viewer.nationalmap.gov/basic...vail=&refpoly=
T8
Old February 3rd 20, 02:23 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
experiment.
Very little, and that was on steeper, more defined ridges - the ridge
north of Omarama and on the Pennines under Cross Fell. I take your point
about marking the start of a ridge climb.
https://viewer.nationalmap.gov/basic/?
basemap=b1&category=nbd,ned,nedsrc,histtopo,nhd,na ip,nbdmi,gnis,smallscale,nsd,vectorcmb,ntd,ustopo, woodland&q=&zoom=12&bbox=-82.25360870,36.76584198,-81.94805145,36.91201927&preview=&avail=&refpoly=
FWIW GoogleEarth can give rather good topographic views if you move off a
bit (1km or so) and then zoom right in, almost to the point where it
wants to switch to streetview. Then moving your viewpoint around lets you
easily pick out high points, ridgelines, etc.
Martin | martin at
LXNAV 8000 OAT Incorrect Deming Gray Soaring 27 December 13th 18 10:05 PM
Seeking help regarding SeeYou waypoint management [email protected] Soaring 2 February 16th 18 01:19 AM
Warning: GPS data incorrect Cheetah236 Instrument Flight Rules 17 September 23rd 05 07:50 AM
SeeYou to LX7000 Waypoint Task Files Ken Kochanski (KK) Soaring 1 May 28th 05 12:22 AM
Incorrect Coastlines..Channel Islands....HELP !!!! Derek Simulators 0 March 23rd 05 11:50 PM
